factory keyless entry install
in the pic below is this the gray connector circled in white???? and also in the pic the connector circled in red is the connection for the keyless module and the wire circled in yellow is a radio antenna wire that plugs into the side of the module all of these are installed in my mustang from the factory without the keyless entry option on my stang......thanks for the picture driggins...
wait so what if you have the alarm and the keyless entry, I pulled the alarm cartridge out because it was acting up, and then the keyless did not work. Is the keyless entry hooked up to the alarm system as well?
I had the same problem, and when I took mine out it had all the wires labeled, and I seem to remember some of the wires were for the keyless entry. Was yours in the trunk or under the dash?
