Something is draining my battery
What is a good way to diagnose what is draining my battery? Something is draining it when I am parked. I cannot visually see any lights on or anything. I guess one way to temporarily combat this is to dis-connect my battery when I am parked but this is terribly irritating.
Put a meter in series between a battery terminal and the battery post. You'll need your meter set to measure draw and make sure you dont have anything turned on or you can blow the meter's fuse. JRichker has a nice write up, IIRC.
Good luck.
Actually, those links from Saleen can really get you rolling. Those were resources I don't think I'd seen before. :nice:
If you can get Saleen or Jrichker (or Tom and a select few others) to post on a thread like this, you know you've gotten top-notch assistance. :nice: Some day I hope to know as much as they've forgotten.
EDIT: forgot one reason for posting. Have you load tested the battery? When batteries are on the outs, they wont deep cycle for crap. Getting the battery load-tested can be a decent idea (I've had bad batteries right off the shelf). When batteries are on the outs like that, they require frequent charging, even if parasitic draw is relatively minimal (e.g., 100 mA).
Good luck.
My battery was being drained by the lights in the vanity mirrors on the sun visors. Velcro got old and would not hold the cover down tight enough to close the switch. I used a meter as suggested in the previous post then pulled fuses until I saw the drain go away. Then it was just a matter of figuring out everything that ran through that particular circuit. Those vanity lights were out of sight and mind and took a bit to figure out. Good Luck
do as Hissin said with the draw test (in line with the ground wire from the battery works good and is easy to install there) and pull every fuse till it changes the draw on the meter....could be the stupidest thing that you would never think of. I just did this on a 99 blazer and it ended up being the rear hatch door lock actuator was siezed and it was causing a draw.
I just had this happen to me - drained twice in two days. I found that the Alternator voltage regulator had failed. check the current draw to the alternator wires to see if it is the problem. Start by removing all the wires on the solenoid with the car off and checking those wires for drain with the key off.
I found mine when after the second drain I popped started the car with my clutch (still had some battery) and the voltage stayed at "0" with the car running. New alternator and battery did the trick (the battery was 7 yers old so I replaced it too).
i had the same problem with the alternator, couldnt figure it out, and worst of all, it happend about a half hour before i was off to a race weekend, re-built the alternator with new plugs and its worked fine ever since, i have never seen the volt meter so high on this car
K guys kinda embarrassed to ask this. but how do I use/read my Ahm meter. I am using the following link to test the battery
http://www.autoshop101.com/trainmodules/batservice/118.html
But I am not sure what to set my meter to. I think Ohms is resistance so I dont use that. I am thinking volts but I am not sure which setting to use. 200m 2000m 20.... I have a actron cp7665.
Any help appreciated.
This is the meter I have
http://images.google.com/imgres?img...mages?q=actron+cp7665&svnum=10&hl=en&lr=&sa=N
my alternator wasnt killing the car when it was running, but it wasnt charging enough to give it a full charge when running either, i took it off and brought it to the local parts store, they tried to test it, but the plug(s) on it were bad, changed them and the brushes and it worked great, havnt had a problem since
But I am not sure what to set my meter to. I think Ohms is resistance so I dont use that. I am thinking volts but I am not sure which setting to use. 200m 2000m 20.... I have a actron cp7665.[/qutoe]
You have to set your meter up to measure current so it will be an amp setting. I'm not sure which scales that particular meter has so set it up for a high amp reading and step it down until you get a decent reading.
Step 1.) Find the instruction book that came with your Multimeter. Read it and familiarize yourself with how it works and how use it. If you lost the book or didn’t get one with it, do a Google search on the web to find the manufacturer’s web site & download a copy of the manual.
Step 2. ) Make sure that you know what test lead plugs into which jacks on the Multimeter. There are usually several different jacks on most Multimeters, and they have different functions. Make sure that your battery(s) in the Multimeter are good: if you have any doubts, replace the battery(s).
Step 3.) Once you are sure that the Multimeter is functional and you have the leads plugged into the jacks for Ohms ( the upside down “U” symbol), do some simple measurements to make sure that you know how to use it correctly. Set the switch to the lowest range and touch the leads together: you should not see “nothing” but you should see 1.0-0.3 ohms. Measure a 60 watt light bulb: cold it will measure about 17.5 Ohms. It you measure it while it is hot, the reading will be greater.
Step 4.) Make several test measurements using the ohms function and the DC volts function. Remember all resistance measurements must be done with the power off the circuit. This avoids false readings and possible damage to the ohmmeter.. Repeat steps 3 & 4 until you are sure that you can do it without making any mistakes.
Step 5.) Then see http://www.autozone.com/servlet/UiB..._us/0900823d/80/1d/db/3c/0900823d801ddb3c.jsp and carefully study ALL the information under the Heading Chassis Electrical, Basic Electricity – Understanding & Troubleshooting
