Small Problems... Nothing Big...
Adam95GT
2,564
Burlington, NJ
My head unit has always had a problem since ive gotten the car... plays raido fine.... cd/aux nont so much crackles and distorts.... i changed the head unit.... still same problem... what would make it do that???? also in the rain/snow.... my brakes feel really weird.... its kinda like im sliding.... but on rice krispys... abs messing up??? i donno lol
Adam, some of these cars have a ground behind the driver kick panel that seems to be problematic for some. I don't know if it could be an issue for you but figured I'd throw the idea out so someone else could say yes or no.
Good luck.
I can think of 2 occasions when my ABS saved my car from getting totalled. I got caught in a bit of snow last week, going down a slight hill in 2nd gear with my foot off the gas, the rear tires started to slide (from engine brake) and the car went sideways. So I put it in neutral and with the ABS i was able to steer it straight again. If my brakes would have locked-up I sure as hell would have ended-up backwards and would have deffinetly hit 2 or 3 cars at the bottom of the hill. The other time I was coming out of a gas station and there was a bit of ice at the end, and my ABS kicked-in. I would have slid into lots of oncomming traffic should my wheels have locked-up.
Anyways, don't pull the fuse. Sounds like its working like it should.
Alright guys well i finally went searching for the ground wire under the drivers kick pannel.... and found a bunch of cut up wires hidden.... im not sure if it was from the alarm system that the car once had in it the the po had removed or what.... but i couldnt find the ground.... can someone tell me where it is??? and how to fix my ****ty stereo problem
ill have pictures late rfor some reason my camera wont let me upload....
