hidden starter button?
JGT
Charleston, SC
it's probably been posted somewhere before, but i don't know what exactly to search for. i'd like to put in some kind of hidden button that when pressed, will allow the car to start. if it's not pressed, when you turn the key it wont start.
"Fuel Cut off Kill Switch
On 87- 91 cars the fuel pump relay is under the seat, 92 and later cars ,the fuel pump relay is under the Mass air duct on the passenger fender well. Cut the red/black wire going to the fuel pump relay. Splice a 16 or 18 gauge wire into the wire and connect it to one side of the switch. Connect the other side of the switch to the other end of the red/black wire going to the fuel pump relay. When you are done the switch should be in the middle of the spliced red/black wire that goes to and comes from the fuel pump relay. Using the inertia switch side of the circuit allows you to use light gauge wire and light duty switches. There is less than 1 amp going through the circuit, so you don’t have to worry about voltage drop across the wiring depriving the fuel pump of electrical power.
You will probably want to take out the seat, but when you do it'll be sitting right there. Little black box on an L bracket. I couldn't say before or after, Mine goes directly to the pump itself. I would say before the relay though, to be safe. No reason to have it working any more than it has to. On a side note, always make sure you turn it on before you turn the car on. Do it before you even put in the key if it'll help you remember. I forgot a few times and it messed up my computers ignition sequence and I had to clear the memory and re teach it how to start. You don't want to lose your injector priming before ignition."
copied this down long ago in a txt file from an old post..
we wired up a hidden starter swithch on my buddies VW corrado. We hid it under the shift boot in the corner so all he did was get in, turn the key forward and hit that switch. was pretty cool and funny as hell watching someone try to start it LOL
Pretty good place to put it, simple but no one would expect it there...
I put in a switch inline with my starter wire to the starter solenoid(the little red wire), with it off it wont crank, flip it and it will.....I put another hidden one somewhere else inline with the same circuit which i might flip if i leave it somewhere in a bad place or something, so even if ones turned on and the other is off and wont let it crank. A better idea is to do it with the fuel pump circuit, and if you have a MSD box you can also put a switch in one of the wires so it wont spark, I believe its the white wire.
Oh yeah, I agree with the guy above me, its hilarious to throw ur keys to someone n be like yeah sure you can drive it, they get in and go to start it and it wont start ahah.....then get in secretly hit the switch and it starts right up, n they try and figure out what just happened haha.......I also did that with just my door....it had the problem where u needed "the touch" to open it, just lift up and kinda twist the handle and it worked (worn bushing or w/e inside the door), I got so many girls with it, "heres the keys if you can open it you can drive it" hah not one could open it, they were looking underneath the handle for hidden switches and stuff when i opened it perfectly
