Trick Flow Track Heat vacuum hoses
5.0 Nostalgia
904
CT
My car has been down since August. I have most of it back together but I can't remember where all the vaccum hoses under the upper intake go. Can someone help me out? I have one going to the PCV and if I remember right, one goes to the charcoal canister.
Thanks.
i just run the hoses in the back of the intake towards the firewall the ones in front of the intake towards the radiator i just block those car run fine like thaT. im not using any emissions dont know if this helps but im using the trick flow intake and a 1inch spacer makes it easier to get to the vacuum line
Thanks for the help. I don't have the spacer, so it is a PITA to see under there without taking the intake off (I don't feel like taking it off again, but I will if I can't get this straightened out). I have the PCV hose hooked up, but I have to get another hose to reach the charcoal canister (on the GT40, that hose went on the EGR spacer). Right now there is one other hose coming out the back and looping towards the front, but there seems to be nowhere for it to go. That is the one that has me stumped.
Here is a picture of it. It's hard to see because the upper intake is black and the valve covers are polished.
I THINK that hose might be the one that goes up to the vacuum tree on the firewall. But I'm not %100 sure.
Good point. I forgot about that one. That picture is a selection from a larger picture. I just looked at the full picture and all the connections on the tree are full. So I must have already put that one on too. Like I said, it's been a while since I did this. I will have to go out to the garage and check on that. Thanks for the info. I pulled this hose directly off the GT40, but I just can't remember where it goes, or if it was on the front or back. :bang:
