I think I have some timing issues going on also. The way my balancer is set up is I have the the following marks going from left to right if you are looking at it to set the timing: 10 C 0 T 10 20 30 40.
I have my timing set at 14 with spout out. Its basically set between the 10 and the 20 marks. I guess this is before TDC I am not sure. I know if I turn my distributor to the left like towards the altenator it smooths out but if I move it to the right towars the battery it gets really rough. But right now the car just doesn't act right all the time. At times you can floor it and it just doesn't have any power it lags but then it will take off on you at other times. It seems like its differen't from one traffic light to the next. The other thing it will do from time to time is if you stomp on it from the get go it will run half way decent but if you drive normal and then go to stomp on it it will lack power sometimes. You have to let off the pedal and then stomp it again. Any ideas as to whats going on here and am I setting my timing right?
