Hmmmm
Today, 04:51 PM
Also you have to wire in the neutral safety switch. Non 5 speed cars have it on the harness too. You plug it into the tranny. Also you need to hook up the reverse light switch, also on the tranny. I went to a wrecking yard and got the small harness that connects to the tranny off a 5 speed. Make sure you just go ahead and take the dash out, I did and it made my life easier. The driveshaft was the same length also. Make sure you have good u joints and a good rear seal in the tranny while you're at it. I had to do it afterward. 25 dollars total. Good luck =)
You're welcome
