Fuel Pressure Question
OK......here is my question.
Last year I had 30# injectors, the stock fuel lines, stock fuel rails and a 255lph fuel pump. When I turned on the car, the fuel pressure went up ti 42lbs and stayed there for a few hours then started to drop.
This year I have 42# injectors, Russell braided fuel lines that are taking the place of the hard chrome lines that go from the lower passenger side of the engine compartment to the fuel rail, stock fuel rails and the same 255lph fuel pump. When I turn on the car the pressure goes to 42lbs, then starts to drop to 30lbs immediately. It stays there for a few minutes then drops to 20lbs were it stays. I cannot smell fuel, have checked everywhere for leaks and have found nothing.
Could the braided lines be the cause????? I have no idea.
I have also noticed the 42# injectors seem a little noisy compared to the 30# injectors? Normal??
Any help would be appreciated.
here is no info about your car's model year or mods, which make it hard to tell what's in your car.
That's why it is a good idea to use the sig under the user control panel (User CP) option. It allows you to post your car year & mods, which help greatly when troubleshooting things. No, it is not there for us to snoop and see any "Secrets" you have hidden away under the hood. Be a good stangnetter and update your sig for future reference & don't keep us guessing.
Do you mean that the pressure bleeds off after you shut the car off? I think that all cars will looose fuel pressure after the pump is shut off....only natural. Im also assuming you have an adjustable pressure regulator and a gauge on the fuel rail. give us a little more info....Im assuming you have a pretty serious combo to necessitate 42's.
Volumetrically I can see there being a bit more of a lag per se, but I would think if you had a properly running regulator all would be fine. Are you still using a stock regulator?
Also, I am assuming you went with a new fuel pump correct? Was it BBK, Walbro....
