A little heavier oil may help. Could be a chain tensioner not pumping up (or a bad one) or you have valve train noise. I know it goes against what most here believe as far as oil additives go but try some Lucas Oil or similar before you replace 50 bucks worth of oil. If it quiets down then you know a heavier oil will suffice. Should be OK until the next change.
