DoubleONegative
Not kewl. Whats broken? Did you do it at the track?
prolly just the front seal....and no i havn't been to the track...soon though
Tried it this past weekend. Runs lean so I tried to use the Tweecer to richen the fuel curve especially the lowest 10-15pts because it was running rough and lean on start up. Helped a little but it still goes super lean when decelerating. Was in Vermont the previous couple of days so I haven't messed with it again.Bryan did you try out the tune I sent you yet?
Real glad to hear that was the problem. Now it should be a lot less stress on you.
Been driving my car a little. Running better. Turned the fuel pressure regulator another quarter turn to add some more fuel. When I stomped on it the AF ratio would be in the 13s which is too lean. Now its in the 11s and 12s. Running real strong.
Today is my 39th birthday. Only one more year till the big 40.
. Trust me. Put your fuel pressure to 40psi and it should run like a champ. Messin with the FP may have caused your head failure.... Your killin me here. Thats why it was so lean. Don't touch that tune!!!! Leave it....
Travis do you know of a way to use some parental controls on the PS3. I wasn't sure if there were any. One if not both of the boys were downloading **** clips off the internet onto the PS3. Yeah I know that is wonderful thing. I had been wanting to take a look at the Ps3 for a long time to see what they had been downloading and I wasn't amused. Their mother wasn't happy either. For now they won't be allowed to hook up to the internet.![]()
Redline_351r,
This is Adam from the races today at New England Dragway.
Hope you didn't get caught in too bad of a rain going back up north.
I'll try to get that video of your run off my brother tomorrow.
I forgot to mention that I swapped the 28 spline axles with 31 splines when I did the 3.73s... but maybe the 94 Cobra already has them. It's a good idea for future HP/TQ increases was why I did it... since it already apart anyways.
You need to shorten your sig..![]()
Not sure how long to put them in. I'am figuring 3-4 hours on the safe side. I have plenty in stock. The labor will be cheaper if you buy them through me, but whatever you want to do. I can get them next day for $200 SHIPPED!!!Not sure how long to put them in. I'am figuring 3-4 hours on the safe side.
You'll need three quarts of gear oil and friction modifier.
Don't worry about the shims, if you already have the gears comming, thats fine. Normally the rate is $20 more per hour. I don't care either way. They better be FMS gears though.. Let me know. It will be in the afternoon until I can get to them, so there problably won't be any racing that day. I work at the raiload in the mornings now and it sucks..
Yeah they are FMS, Wouldnt get anything but those. Like I said I have to call the site tomorrow and see if the order was actually cancelled and why.
After the gears are done its time for some 31 splines and some weld pro stars and MT ET Streets
