- Aug 7, 2004
- 366
- 0
- 17
I have an 07 Gt with the premium package. my instrument cluster only has 2 gauges, should it have 4?
Darkfire just beat me to it and he's right...
the extra gauges are part of the IUP (Interior Upgrade Package) along with the message center (under the speedo), MYCOLOR (changes the color of the gauge faces) and a few other interior accent pieces
You're not necessarily out of luck....my '07 did not have the IUP, and I wanted the cluster with the message center. On the left hand side of the middle of your dash, across from the traction control switch, there is a blank plug which is the same size and shape as the traction control switch. Pull the blank out. If you have wires there, plugged into the back of the blank (my '07 did), you most definitely can upgrade. If the wires are not there, it can't be done.
You'll need to order the cluster, and the new switch. The dealer will need your VIN and odometer reading, as this information has to be downloaded into the new cluster. It took like a week for my cluster to arrive, so I estimated what my mileage would be when I took the car in for the swap.
