68 302 casting numbers
hi guys
thanks for all your answer , i'm reaching , what could be the casting numbers to buils a correct 68 302 , so i need all the casting numbers for all parts
thanks for your answer dave , but i don't found any links in the FAQ .... can you give it to me ?
regards
Block can be one of these; C6AE-C, C8OE-A, C8TE-B, plus the mexican block (don't have the numbers for that one) Heads can be C8OE-F, J, K, L, M. C8AE-J,C8DE-F. Intake would be C8ZE for the 4 bbl. I don't know what the 2 bbl was. As for everything else, good luck ! Any 302 part with a 68 date code would probably be correct.
ok thanks you , i will give him those information
thanks you everyone , you are all very sympathic to answer to our question,
found documentation is not easy here ...... understand it is harder :p
BEST REGARDS
guillaume
