Anyone know how to fix the Map Light?
SuperStang83
1,693
Boyertown, Pa
I took my Map Light apart last night to try and fix it, but I don't think that it comes apart at all. I am getting power to it and into the switch, but after that I lose power. Is there an easy fix for this or not?
Jacob
You have to drill out the plastic rivets, pull the spring perch off, and put a spacer or different spring to close the switch. The spring loses its ability to close the switch. Then glue it back together. I've done two so far. Good luck.
Stang it was super simple. I didn't believe it myself. I just drilled the switch apart like Aryan said and put something in there to help the spring get more pressure on the contact points. Funny thing is I actually cut a small piece off a popsicle stick and put it in there for my buddies car and it works perfect now. I put it all back together and just epoxied it so that it would stay. No one will ever see what it looks like on the inside anyway.
Cool. Thanks!
I'll try it!
