car wont start!!!
00GTpony
162
my friends 95 GT wont start.. doesnt even turn over... Brand new battery, brand new starter, solidnoid clicks when you turn the key, so its not that. You can still push start the car though with the clutch.. i dont no what else to check.. Any idea?
Go over the primary power cable connections. The power distribution center's connections are prone to getting corroded and resistive and can cause such an issue. Jiggle the battery cables around.
I have used a jumper cable to test OEM cables before. I run the jumper in parallel with a given OEM cable. Then try to start the car - when it starts, whatever cable is being paralleled is deficient.
Good luck.
seriously try and take the battery back to the store and have them check it. I had that problem too. or something like it. then check the battery cables. if they are old or questionable replace them.
I did this and my car started. fixed it today. you can find my other post too. great stuff from the other forum users.
Good luck.
I did that too. had some white poweder stuff on the selinoid blew that off. i'm not sure if that hepled or not but its free.
Check battery voltage, it should be at least 13.2 volts. Now check battery voltage at the starter solenoid, it should be the same. Have someone hit the key and check the voltage at the starter cable post of the solenoid. You should have close to the same as battery voltage. If you have battery voltage at that point you will need to check the connection at the starter. If you don't have battery voltage then you need to check the ignition switch input to the solenoid. You should have at least 12v at the small ignition switch wire while the key is in the start position. If so then you have a bad starter solenoid. If not then you have issues with the ignition wiring.
No Crank checklist for 5.0 Mustangs
Since some of the tests will bypass the safety interlocks, make sure that the car is in neutral and the parking brake is set. Becoming a pancake isn’t part of the repair process…
Check battery, terminal connections, ground, starter relay switch (also known as solenoid) and starter in that order. The clamp on with 2 bolts battery terminal ends are a know problem causer.
A voltmeter is handy if you are familiar with how to use it to find bad connections. Measure the voltage drop across a connection while trying to start the car: more than .5 volts across a connection indicates a problem.
See http://www.fluke.com/application_notes/automotive/circuit.asp?AGID=1&SID=103 for help for help troubleshooting voltage drops across grounds.
1.) Will the car start if it is jumped? Then clean battery terminals and check battery.
2.) Check the battery to engine block ground, and the ground behind the engine to the firewall.
3.) Jump the big terminals on the starter relay next to the battery with a screwdriver - watch out for the sparks! If the engine cranks, the starter and power wiring is good. The starter relay is also known as a starter solenoid.
4.) Then pull the small push on connector (small red/blue wire) off the starter solenoid (Looks like it is stuck on a screw). Then jump between the screw and the terminal that is connected to the battery. If it starts, the relay is good and your problem is in the rest of the circuit.
5.) Remember to check the ignition switch, neutral safety switch on auto trans and the clutch safety switch on manual trans cars. If they are good, then you have wiring problems.
Typical start circuit...
Diagram courtesy of Tmoss &Stang&2birds
attachment.php
See http://www.autozone.com/images/cds/gif/large/0900823d80195963.gif for 88-90 year cars
See http://www.autozone.com/images/cds/gif/large/0900823d80195964.gif for 91-93 year cars.
See http://www.autozone.com/servlet/UiB..._us/0900823d/80/1d/db/3c/0900823d801ddb3c.jsp for 94-95 model cars.
6.) The starter may be hung, loosen up the bolts that hold it on, and give it a good whack with a big hammer. Tighten up the bolts and try again.
7.) Pull the starter and take it to Autozone or Pep Boys and have them test it. Starter fails test, then replace it. If you got this far, the starter is probably bad.
