R romgolferman Founding Member Mar 24, 2001 355 0 0 St. Louis Oct 30, 2007 #1 Oct 30, 2007 #1 89 5.0. where is the oil sending unit located at.
Hickfied Member Nov 9, 2005 413 0 16 Morganton, NC Oct 30, 2007 #2 Oct 30, 2007 #2 When looking at the engine from the front of the car, it is behind the timing cover, on the right side, screwed into the block.
cenok is family 15 Year Member Jun 25, 2003 1,409 69 79 Norman, Ok Oct 30, 2007 #3 Oct 30, 2007 #3 ^ what hickified said. it's a 'bell' looking thing with a single wire pushed onto the top of it.
HISSIN50 "How long does it take to get help in here? 15 Year Member Nov 29, 1999 31,179 34 129 Oct 30, 2007 #4 Oct 30, 2007 #4 ........ above the oil filter.
PUNISHER RACING Active Member Aug 27, 2007 1,124 0 36 FORD CITY, PA. Oct 30, 2007 #5 Oct 30, 2007 #5 .....below the header(what I had to)
SuperStang83 Founding Member Mar 21, 2001 1,693 0 49 Boyertown, Pa Oct 30, 2007 #6 Oct 30, 2007 #6 You should be able to see it pretty easy if you look down on the drivers side.
I iwashmycar 20+ Year Stangneter Apr 7, 2004 1,236 1 39 Columbus, Ohio Oct 30, 2007 #7 Oct 30, 2007 #7 HISSIN50 said: ........ above the oil filter. Click to expand... yeppp....its pretty easy to see from underneath right around there too
ShortThrow50 Member Oct 22, 2006 923 2 16 Pa Oct 30, 2007 #8 Oct 30, 2007 #8 Hickfied said: When looking at the engine from the front of the car, it is behind the timing cover, on the right side, screwed into the block. Click to expand... cenok is family said: ^ what hickified said. it's a 'bell' looking thing with a single wire pushed onto the top of it. Click to expand... HISSIN50 said: ........ above the oil filter. Click to expand... PUNISHER RACING said: .....below the header(what I had to) Click to expand... ....underneath the hood
I iwashmycar 20+ Year Stangneter Apr 7, 2004 1,236 1 39 Columbus, Ohio Oct 30, 2007 #9 Oct 30, 2007 #9 ShortThrow50 said: ....underneath the hood Click to expand... this man knows.......
ShortThrow50 Member Oct 22, 2006 923 2 16 Pa Oct 31, 2007 #10 Oct 31, 2007 #10 iwashmycar said: this man knows....... Click to expand...
Fast63 New Member Sep 20, 2007 717 0 0 Oct 31, 2007 #11 Oct 31, 2007 #11 ShortThrow50 said: ....underneath the hood Click to expand... Somewhere on your car...
5spd GT "the 5.0 owns all" Founding Member Aug 7, 2002 9,516 6 99 Arkansas Oct 31, 2007 #12 Oct 31, 2007 #12 I am pretty sure you can find it by now I would put some thread sealer when you reinstall the oil pressure sending unit. Bad (inaccurate in fluctuation) oil pressure sending units are a common problem with the misreadings of pressure on the stock guage.
