Best brand oil filter?
Thats what I would like to use but I cant get anyone to cross reference the filter I have now which is a STP S3531. The original filter no long works on my car since I installed the UPR K member so I was told about this filter but would like to know which one it crosses to in a motorcraft.
here is the spec sheet from Wix filters for their version
zoom
Part Number: 51392
UPC Number: 765809513921
Principal Application: Acura Integra (86-87), Honda (80-87)
All Applications
Style: Spin-On Lube Filter
Service: Lube
Type: Full Flow
Media: Paper
Height: 3.141
Outer Diameter Top: 3.660
Outer Diameter Bottom: Closed
Thread Size: 22X1.5 MM
By-Pass Valve Setting-PSI: 8-11
Anti-Drain Back Valve: Yes
Burst Pressure-PSI: 275
Max Flow Rate: 11-13 GPM
Nominal Micron Rating: 19
Gasket Diameters
Number O.D. I.D. Thk.
Attached 2.538 2.224 0.200
For the money, the Motorcraft filter cannot be beat. It is a exceptional filter that I would easily pay $10 for. Ford wouldn't recommend it unless they knew it does the job well. If I cannot get a Motorcraft I usually spring for the Mobil 1 filter. The M1 filter is made of sythetic fibers etc. and probably is the best one for race applications. I suggest you try the Mobil1 filter before buying a relocation kit. The Mobil1 is considerably shorter than the Motorcraft, etc. and I am fairly confident that it will work with your setup.
