What kinda springs/coil-overs are you running that you don't get any rubbing? Must be stiff. Or you have a really good alignment so it tucks the wheel. I use to get rubbing with my Eibach Pro-kit and 24mm offset 245/40/18's
I have BBK springs which drops the car approx 1.75". I have Tokico HP shocks and struts, Maximum Motorsports LCA. I used 94 spindles up front. I have UPR caster camber plates for the additional movement needed for alignment .
My car rides nicer now than it did stock. The only time it rubs, is when I am turning the wheel at full lock in a parking lot or something. When I drive it, even going over a big bump, it does not rub.
