Hey Gang:
Just wanted to let everyone know that the car and I are still alive... It is running and I believe will put down some pretty good N/A numbers this spring (high 10's perhaps)... I don't have the squeeze installed and will probably run it N/A through the summer and then do the juice next winter... Will be putting the final touches on it this winter which "might" include new paint... I will be staying with the Emerald Green, but perhaps with a little more metal flake... I also want to put a simple silver graphic that follows the C-pillar down and then up towards the front door... This is just to change things up a bit... I might also paint the cowl with the same silver... For those of you who might not know what all I (and KillrB have done to the car in the past three years - here's a little list of the hight points:
I'll be tuning the car with my PMS...
Other than little stuff, the only major thing that I have left is that we moved the battery box to the center of the rear hatch were the spare tire goes. I need to finish off that area and then put down the rear hatch carpet.
The last thing I need to do is license the car... The project took so long that the license expired!!!!
Hope to see you all soon....
- 408 stroker motor with forged internals
- Spyder intake.
- 42 lb injectors.
- Jay Allen custom cam.
- 90mm throttle body.
- Anderson powerpipe.
- Hooker LT headers.
- Lentech tranny
- PA Performance tubular K-member and A-arms.
- Six point cage with rear shock brace.
- Line lock.
- Aeromotive fuel system w/sumped tank.
- Eibach rear drag springs with air bag.
- Maier cowl hood w/vents.
- Arm rest delete.
