yes its a manual its got a 3.55 rearend and 31 spline axles i have asked around and have been told to launch around 4000 and shift at 5500 does this sound about right?
i would shift around 6k. i was just playing with my xc2 and remember the default rev-limiter is set at 6400 rpm.
Yes, BUT!
On bolt on Stangs the shift point for the best times at the track is 5200-5500 rpm.
Cammed stangs can go a bit higher, but I think blown Stangs shift the same as us N/A guys?
i stand corrected, i assume thats the end of the powerband?
take a look at my dyno sheet
Looking at your Dyno sheet I'd shift at 5300![]()
It's where the HP plateaus not the TQ right? (I know it's not where HP/TQ intersect... not that dense since it's the same for every one)
No. You want it so when you shift you're back into the optimum power band after the RPM's drop. Depending on transmission/gearing the best shift points can be anywhere between 5600 and 6000rpm in these cars.
