3 days ago I cleaned my maf with maf cleaner , clean my iac valve even it's been here only 6 months. Took all fuel injector out and clean it with brake cleaner
Now my car bogs down real bad at low rpm. If I just tap the gas and let it out then it barely idle and goes to like 200-300rpm and try to die unless I hit gas.
When I try to take out maf it damage the area where one of the screw socket got damage so I just superglue it to make it sit tight and nice. Can I just buy that black adapter where maf sits ? Where can I order it from ? My car runs like **** but at higher rpm and when engine warm then it seems to run fine.
I seafoam my car yesterday , half tank in fuel tank and half thrue vacuum upper intake. That didn't help.
Fuel filter is 1 month old, egr is 3 months old , iac is about 6 months old and spark plug is 6 monts old with autolite 764 copper
Did I damage my fuel injector cleaning with brake cleaner ?No DTS but my car is bogging real bad, even I smashed gas but nothing happen and almost no power at all but after few secound it runs fine. What might be the problem ? Going to change my old and spark plugs tomorrow.
Help
Help
