Oil Capacity?
It is 5 no matter what the dipstick says.....Mine doesnt even register. So I dont even check it anymore. MY car doesnt leak oil and as long as your oil pressure is up then I wouldnt say you are too low. Change your oil a little more often if you are worried. I keep my changed ALOT to keep the engine clean
Same here, mine reads about a Half Quart over the Full line with 5 Quarts and a New Filter. The P/N on my Dipstick is F1ZE-6750-DA, maybe there is a different Dipstick out there that will read correctly...
It is such a pain. Oh well. I took out roughly 1/2 qt. to make sure. still reads overfill!
And yes, i am draining both plugs.
I know this is OT but its a funny story, I stopped at the Local Ford Dealer for a Filter and a couple Drain Plug Gaskets. The Guy walked away and came back and set a Filter and 1 Drain Plug Gasket on the Counter, I told the Guy there are 2 Drain Plugs and I need a 2nd Gasket. Instead of just giving me the damn Gasket the Guy got confrontational with me and tried to tell me I must be draining the Transmission because there is no such thing as an Oil Pan with 2 Drain Plugs. I hope the Guy walked in to talk to a Mechanic after I left to find out what an ass he was!
