post your pistons, cubic inch, heads, and cam specs, that will help out. thanks.
Block is just a simple stock 302 just cleaned up .030
Piston Specs:
Bore (in): 4.030 in.
Bore (mm): 102.362mm
Piston Style: Flat top, with four valve reliefs
Piston Material: Hypereutectic aluminum
Compression Distance (in): 1.605 in.
Piston Head Volume (cc): +8.00cc
Wrist Pin Style: Press-fit
Pin Diameter (in): 0.912 in.
Piston Ring Thickness: 5/64 in. x 5/64 in. x 3/16 in.
Cam Specs:
Intake Duration at 050 inch Lift: 221
Exhaust Duration at 050 inch Lift: 225
Duration at 050 inch Lift: 221 int./225 exh.
Advertised Intake Duration: 275
Advertised Exhaust Duration: 279
Advertised Duration: 275 int./279 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.499 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.510 in.
Valve Lift with Factory Rocker Arm Ratio: 0.499 int./0.510 exh. lift
Lobe Separation (degrees): 112
Intake Valve Lash: 0.000 in.
Exhaust Valve Lash: 0.000 in.
The reason i'm asking this is because i'm trying to figure out what heads to go with. With the pistons being aftermarket I didn't know if they would already have larger reliefs. For cylinder heads i'm torn between TrickFlow Twisted Wedges, 185 AFR's, or Tri-States.....
