Explorer serpentine pws alt ac bracket D Hearne Help!!
dbfarr
191
Boise ID
I've got a 96 exploder engine, I've already purchased the balancer and water pump for the explorer... But I went to the yards today, seems they just recycle the bracket.
Even more annoying, they told me if the had it, they'd want $65, meanwhile they get what, $1.50 for it when they recycle it:bs:
Anyway, I need to source the bracket and a pws pump, any ideas about alternate models that will provide the compact accessory system.
Maybe someone has this stuff sitting around collecting dust?
D Hearne, any suggestions.
Don
The Explorer/Mountaieer accessory setups were unique unto themselves, the only part of these setups that interchanged with any other vehicles that I know of was the timing cover. You're not clear on what bracket you're talking about either.
All I have right now would be,
96 Explorer timing cover
96 explorer damper, with pulley attached
96 explorer Water Pump and pulley
So I guess i need the Power steering bracket, the Alt bracket, and the tensioners
From what I understand, the accessories bolt directly to the cylinder heads, on the Explorer/Mountaineer and the 94-95 Stang (it would also apply to the 88-93 T-Bird/Cougars as well, the 94-95 Stang setup was borrowed from those applications) I haven't had access to these setups to study them though so I cannot tell you for sure that this is true.
I have all this stuff if you want it . . . brackets, P/S pump, A/C compressor and alternator.
The stuff I have came on an '98 Explorer engine I purchased that I installed in my '70 Mustang. I used a set of '87-'93 Fox-body Mustang brackets, A/C compressor, P/S pump and '94-'95 130-amp alternator on mine, so I don't need them.
I'd sell all of it to you for $200 + shipping, and they should be in pretty good shape.
Let me know . . .
$200 is a bit more than I had planned, are you willing to negotiate?
If so PM me.
Don
I just did a quick search on car-parts.com to find out the lowest prices for the parts; I found an A/C compress for $20 + shipping, an alternator for $20 + shipping, a P/S pump for $20 + shipping, and was unable to find any of the other components there, including the P/S pump reservoir, brackets, idlers, etc., so I looked on E-Bay.
E-Bay didn't have any brackets listed there for 5.0's, but they had a couple listed for 4.0's; the A/C bracket was listed at $25 + shipping and the P/S pump bracket was listed at $35. I think the reservoir is the same between the engines, and the lowest priced one I found was around $20 + $8 shipping.
If you put the figures all together, you have $120 for a mixture of prices for the V-6 and the V-8 as the lowest possible price I could find.
I figure I can make at least 25% more on the brackets listed there, and can probably make 10%-20% on the alternator, P/S pump and A/C compressor, so with that in mind, I'd sell you all the parts I have for $135 + shipping.
I don't know where you're located, but if there are any salvage yards around near you, you might be able to scrounge these parts up yourself for less than this amount, and I would encourage you to do that . . . you might end up with a great deal!
135 + shipping sounds pretty reasonable, I'll pm you and work on some details. :D
Once all is said and done, I'll get some pics for posterity's sake and post them. Hopefully that'll sastisfy for the future.
Don
