2. The CURB weight for a STOCK 94/95 vert is 3450#. Options appear to add up 250# on the car.
3. Maximum weight for a STOCK 5speed vert should be right around 3600# and maybe a bit over that.
4. Maximum weight for a STOCK Auto vert should be right around 3700#.
I would think 250lbs for options would be way, way high. I can't see there being more than a 60-70lb difference between the most basic of base 5-speed cars, to a fully optioned automatic. There's just no way there are 250lbs worth of options to be had.
I can tell you with full certanty there is not a 100lb difference between a 5-speed and an AODE. We're talking 30lbs at the most.
Just curious, but where are you getting these weights from? Have you actually weighed these components individually, or are you making an educated guess?(Not Standard) on my car:
17" rims with 245 size tires (I had them) 40#?
A/C 40-45#
Cruise and supporting components 7#?
Body moldings 4#?
remote keyless entry 7#?
illuminated entry 1#?
Leather Seats (leather over top of cloth basically) 25#?
Leather Steering wheel 1#?
Floor Mats 4#
Cassette, CD, multi-cd, amplifier and supporting components..12#
rear defroster and supporting components 5#?
ABS 12##?
Automatic 30#?
Lockup tq converter (part of trans but optional) #?
3.27's na
3.08's na
Block heater ?
4 drivers seat adjustments ?
I come in at 3601#![]()
Just curious, but where are you getting these weights from? Have you actually weighed these components individually, or are you making an educated guess?![]()
So did you weigh a set of factory 16" wheels and tires, then weight your 17" wheels and tires? Looking up the weights on one, then weighing only your tires and guessing the weight of the wheels really doesn’t confirm anything. I’d say 10lbs/wheel sounds excessive.Sure. I looked up wheel and tire size weights and weighed my tires. leather adds a lot of weight but it was a guess. I've weighed speakers and cd components, etc., I personally weighed my ac, and things like the vert top motor, cats, etc.. but some of that is not options.
on the topic.Not excessive at all. You are not including larger tire sizes. Look up the difference in weights in tires alone between 225's and 245's.Each tire is 10mm wider or equivalent of 10 dimes. Thats alot more weight not including upgraded rims from 16-17" x 4. So those figures stay. I am not going to pick it apart but..Just one example without the rims:
"I called up asking for the tire weight of my preferred tire of each size and the wider BGF's were an extra 4pounds per corner based on a larger tire and a different compound. Another 16 pounds of rotating mass kinda defeats the idea of running the light FD wheels in the first place as I'm running them more for the weight savings than the extra traction from a wider wheel."
So add 3# per rim only and that's another 12 and puts it at 28#..still close enough as I did not include several options in MY cars weight anyway.
The Fox body has more chassis flex and s***ty brakes so it pays a price for its lightness.
A stock fully-optioned GT coupe with a T5 weighs 3400lb with a full tank of gas. An AODE version weighs 20lb more. I've lightened mine by 92lb so it's down to about 3330lb with a full tank. Compare that to an S197 GT coupe which weighs in at 3510lb.
The new 2010 Mustang GT weighs in at 3590lb so it's even heavier than the current GT and 260lb heavier than mine (now that mine's 92lb lighter than stock (see Weight Reduction).
Even with that level of weight reduction, there's so much more weight that I could remove and still retain the AC and other creature comforts.
