Convertible top problems!
I have a 95 gt convertible and the top will only go down if i turn the key farther ahead. The ignition was really sloppy so I changed it out and am still having the same problems. Is there any way to fix this or rewire the switch so i dont have to play with the Ignition to get it to work.
Just so there is no misunderstanding of the problem, do the other accessories turn on okay with the key in the run position. Radio, heater fan, etc. The circuit for the top should be switched on at the same time. However, there is an intermediate switch tied into the e-brake and I'm wondering if that is where the problem rests. You'll need to remove the console for access but that's straight forward.
