thanks for telling me the differences between the late n early fox, i wasnt aware (seriously). now i know. like i said, i love new edge's but the new edge cobras go for considerably more than say a 96 or 97 with 90k+ miles...
Since the last two times our SVTOA chapter had dyno days using a Dynojet. Two similarly modded 96-98 Cobras put down in the mid-290's, while a bone stock 96 put down 267. DOHC cars respond very well to modding. Bear in mind, I own one.
Ruffle my feathers? lol @ GB101.![]()
call me ignorant, but can someone explain to me the advantage longtubes have over shorties?
ok thanks. by itself (over shorties) is it enough of a difference to notice though?
My 96 Cobra had 3.73s, O/R H-pipe, Cat-back and a POS Jet chip and no other power mods. It made 299.8 rwhp.Since when is midpipe and CAI worth 40+ rwhp on a 96 dohc? I’d venture to say it’s likely 270rwhp to 215rwhp comparison. When you factor in the 300-400lb weight advantage of the fox….that horsepower differential starts to quickly disappear.
Considering a stock notch is capable of running low 14's/high 13's @ 99mph….I think it could be a drivers race to the finish. Without gears that 96 dohc is going to be a dog down low…and will likely not fully catch up until close to the end of the ¼. Obviously, anything past that and the cobra has the clear advantage.
I agree, the 408 would not need much boost at all to achieve those numbers. My point was the 4.6 could do it for cheaper with less mods and be a much nicer street driven car. It would idle smoother and be more reliable.A 408 built properly wouldn't need a lot of boost to get to 650. I'll bet you could get there on well under 20 psi. Figure 500 hp before boost at the crank. 14 lbs of boost would double that in an ideal world. So let's say 30% loss between the real world and drivetrain. Looks like 700 hp to me.
the new edge technically is a form of the sn, but that doesnt make it an sn. the platform it was built on doesn't make it the same car, there are way more visual similarities between the 4 eye fox and the aero fox than there are between the sn and new edge. i've driven an 02 gt and a 96 gt and the 02 felt better in every category...turning, accelerationlooks are subjective, you are right. and personal taste is what i base my car buying on anyway since i will be the one driving it. if you ask me, the way the sn's wheels sit in from the factory they look like they are ready to go drive on traintracks.
but anyway, it boils down to preference at the end of the day...
My 96 Cobra had 3.73s, O/R H-pipe, Cat-back and a POS Jet chip and no other power mods. It made 299.8 rwhp.![]()
I agree, the 408 would not need much boost at all to achieve those numbers. My point was the 4.6 could do it for cheaper with less mods Not so sure about that. and be a much nicer street driven car Without a doubt if you had a pair of 650 hp motors, the 4.6 would be much more civilized.. It would idle smoother and be more reliable.
You're stupid.
I have found several deals on 96-98s in the 5-7K range in excellent shape reciently but I am trying to get the money together to get one myself so I am not sharing my findsyou find me a 96 cobra for 5 grand with a block in decent shape enough to do all that and id question the durability of it. but seriously if you can find any good deals on 96-7-8 cobras shoot them my way! would be MMMMUCH appreciated!!!
Cars For Sale: Car Details - AutoTrader.comaww you sandbagger not gonna tell me ur finds lol o well i live in so IL anyway probably miles away from where you are and where your oh so awesome priced cobras are![]()
You're stupid.
Seriously though, lets look closer at this.
You buy a 96 Cobra for $5000 or a 95 for $4800. Now for the 96 you take out the motor and hone the block as well as slap in some forged pistons and rods ($1000) and get a set of 03/04 heads ($1000) and an 03/04 intercooler setup ($500) and a Whipple 3.4 ($3600) and thats $6100 assuming you do the work yourself. You have a setup that you can run to 900+ rwhp.
With the 408: 351 seasond block ($500), rotating assembly ($1800), block bored and clearenced (I have no idea, $800?), AFR225 heads ($1600+), intake setup ($600), blower of choice with intercooler ($5000) and a cam ($150).
$10450 total.
Am I wrong here?
Rob, you know I wasnt serious when I called you stupidMaybe I am stupid.Now, let's take those same setups like I discussed and instead of taking the 408 to 14 lbs of boost, hit it hard. How about a ysi trim at 28 lbs of boost. That would take that 500 hp motor to 1500 hp.
Most people on here building a car have no need to go over 500 hp and wouldn't know what to do with that if they had it. Not that I'll post final numbers on here, but I'll put it this way. If I don't run very low 11's, high 10's I'll have a real problem with my car and I'll be ordering the renegade pully set and seeing how much boost I can run without splitting the block. Let's do the math, what does it take to make a 96 cobra run 10's... BTW, where do you think you can get the motor honed and get new forged pistons, rods, and rings for 1k?
