Top Speed with a KB 2.1
No one really goes for top speed, what's the point? Where would you do it?
Likely illegal and not safe, most of us run out of gear too. Top speed to me is a childhood stat, something that matters when you don't know a lot about cars.
+1
also, all the power in the world isn't going to achieve max speed potential. Weight, gearing, aerodynamics plays a huge factor and is one reason why some exotics would top my car despite making a lot less power.
i'll go ahead and tell you from experience that mustangs dont handle for **** at anything above 150 mph.
i topped mine in 5th a few years back just after the T56 install. it pegged the speedo and still had a gear left. that was with under 400 HP on the stock bottom end.
now i dont do anything above a 4th gear pull ever! too much can go wrong
How much HP are you making? Here is what you will need.
Mustang owners should never be concerned about "top speed" the cars are just not safe or designed for it unless specifically built for the purpose by the owner at great expense.
ive put my gt with out a supercharger to 170 and still had plenty to go in 5th gear on a closed road and with just the suspension kit that i had it did not vibrate or shake or in this case try to fly it was smooth as if i was just doing 65 mph on the highway
Ive topped mine out several times (145-150) not supercharged, alot of these guys are scared to go over 100mph because its "unsafe" if that was the case the car would not be allowed to go any faster than that. Find a good stretch of road and give it a go.
i'm gonna have to call BS on that. mine would barely hit 145 as a full bolt on car. that was on a VERY VERY long top gear pull. i dont see it being possible to hit 170 on a non FI car.
hell i dont know if mine would hit that
I've seen 135 before I backed off, but the speedo was still going. The car actually felt 100% stable at that speed. But if you have to make an emergency maneuver, you are pretty much toast.
I tried to top it out post 4.10's, but ran into some TERRIBLE driveline vibes at 130. Sucks because it was pulling much better in 5th at that speed than it did running out of 4th, or just shifting into 5th with stock gears.
No desire to try it again any time soon, but maybe if the right conditions arise.
