- Feb 6, 2010
- 23
- 0
- 1
Its a 96 GT with a PI head/cam/intake, swap all of the bolt on BS and crap as well as a dyno tune.
I started to notice just lately that at full throttle it can start to ping just a little past 5000 RPM's and mainly only in higher gears like 3rd or 4th.
I checked and replaced the fuel pressure regulator on the fuel rail and that helped slightly. I hooked a pressure gauge up and took the car for a ride. At idle its at 29 which is good. Full throttle it goes to 39 which is good but I noticed the PSI can start to drop some after like 5300 RPM's and by 6000 it goes to down around 35 PSI.
Is this normal? do I need a new or better fuel pump? Would a aftermarket regulator help?
