Hi all.
New here & am having a fuel problem with my 2000 3.8 Mustang.
No fuel pressure.
I checked & there is no pressure at the fuel rail. I have listened at the fuel filler neck wile wify turned the key. Silence.
I checked the IFS switch in the trunk, and the button was in.
I checked the fuel pump relay & CCRM fuses & they are both good.
Also the battery is new & I'm getting fire.
I plan to change the fuel filter & test if there is any voltage to the fuel pump, but I'm not sure of what wires to look for. I guess I'll find out when I get under the gas tank. Anyone know?
I'd rather not assume it's the fuel pump & drop the tank, until I've checked everything else.
Anyone know what would be the next things to check & how?
CCRM, PCM, CMP ???
I havent been able to find the CCRM yet.
I used to work as a Ford/Isuzu heavy truck & tractor mechanic but there was very little computer control.
Any info on this would be greatly appreciated.
Thanks.
No fuel pressure.
CCRM, PCM, CMP ???
Thanks.
