2.73 rear gear
hsean
656
69
69
dearborn,michigan
i bought this 96 mustang rear end last year and got to cleaning it up.i looked inside and sure enough its a 2.73:( .what can i expect for a shop to charge for an upgrade to 3.27 or 3.55?is 2.73 really that bad?my car will be basically a nice driver .the motor is stock and i am getting ready to change the fluids and throw the suspension stuff back on.
2.73's aren't "that bad", but a steeper gear is a great upgrade for performance on an otherwise stock car. If the car is a stick, I'd be thinking about 3.55 or 3.73. It it's an AT, then 3.73 or 4.10. Prices vary WIDELY. I've heard of guys getting them done from $2-300 all the way up to $1000+.
I paid $175 for my install...but this was back in 2000
2.73's are what most fox mustangs have anyway stock..not the end of the world. I prefer the low gearing. Just make up for it in HP! :)
way back in 1987 i bought a white gt with an automatic and 2.73 gear in the back off the lot and it was a dog.then i ordered an 90 lx with the 3.08 but considerably faster but it was a 5speed car, i got to enjoy it for 8 months before it was stolen.i am disappointed because i was ready to reinstall everything this weekend and i was told by the guy that i bought this from that it had a 3.27 gear in it.i only paid 120 for the whole rear end so atleast it is an 8.8 rear.i am on the fence right now i don't want any problems with it just would like to spend my money elsewhere right now.there is a benefit to the 2.73 being that gas prices are going up and it will be cheaper to drive with my leadfoot.i am not going to do anything with it this weekend.i am going to give it a week but i think i'll just throw a 3.55 in it.i'm going to start calling around these reputable axle shops .
do a little research and tackle it yourself :shrug:
gear changes are pretty simple if you know what youre doing. Setting preloads and turning tq can get a little complicated if its your first time but its definitely worth learning how to do. Then you can charge other people ridiculous amounts to swap a ring and pinion.
Might be cheaper to bring the axle to the shop as is for the gear change...vs bringing a car.
I'd imagine doing it on a bench would be simplier
Actually i've been told different that it's harder to do on a bench. Didn't ask the reasons why, but i'm guessing it has to do with it moving around and getting the torque settings right.
hsean, i know this is not what you are going to want to hear, but since it's a used rear, you are going to want to overhaul the whole thing while it's apart.
Rebuild the trac lok and all new bearings.
Makes no sense to do it twice.
And since i'm guessing you plan on using this rear in your fox, take into consideration your wheel choice, because the wider rears don't like all wheels.
thanks for the heads up ,i just picked up a 3.27 gear for it so it looks like i am going to do the upgrade.i had 17x9 oem 2003 cobra wheels but i traded for polished 99 cobras so i should be alright there.
I know this is going to sound very negative, but 3.27's aren't worth the effort over 2.73's. One set just sucks less, that's why people damn near give 3.27's away.
3.55's is the minimum that's worth the trouble, me personally i wouldn't bother for anything less than 3.73's.
While I don't think I would spend the money swapping 2.73 to 3.27 I think there still will be a noticeable difference between the 2. I had a 5spd pickup that I swapped the stock 3.08's for 3.42's and I was pretty happy with the improvement.
I practically gave a set of 3.55 away a few months ago .lol I have a friend with a nice capri at work and he loves the 3.27 gear in his car.he has had all the gears through the years and says its a nice gear for a driver.I did the rpm calculator over at the corral and doing 80 miles an hour still pretty low rpms.I do plan on making some trips out of state with it when its done.
I just want to add my $.02...if your using used gears it is important to install them back at the same depth or they could make noise. I mark all the gears with a paint marker when I install or remove them ;)
For a straight gear swap I charge $250 which includes fluid. Like XP stated id also suggest a full rebuild if you plan to keep the car and you have high mileage...makes a huge difference. I also would go 3:55-3:73
I paid 450 for a gear install after the shop told me they would do it for 200. I have never had anyone work on any of my cars other than me since then, and Ive done gears like 3 times, and its really not that hard at all! And just an fyi. I used to have a 90 LX AOD that ran 14.7s.I swapped from 2.73s to 4.10s and ran 13.9 with nothing else done!
Yup, the difference in how long your rear lasts is using good parts, qualified labor and being thorough.
You could put used gears in a used rear and have it be worthless in 6 months.
Or you could do a complete job and have it last 100,000 miles.
hsean, from your description of the 5th gear rpm i'll guess you are going to drive alot or this is a daily driver.
While you may notice a little less mileage on the highway with 3.73's, they are also known for better mileage around town.
Regardless of your gear choice, rebuild the thing top to bottom, or it's likely you will be back complaining of gear whine, the one wheel peel or even worse your axle bearings could go and permanently wear down your axles. (and yes i've had this happen)
Do it once, and do it right.
Thanks for all the replies fellas I definitely want to do this right that's why I am taking it to someone that does this for a living.I am going to have him go through it all and replace the bearings as well.yes I will be driving this thing when its done.I plan on putting the mileage on it and in the future a new 5.0 swap.
Don't forget the carbon clutch rebuild kit.
