Keeps Overheating
All thermostat brands fail or even show up DOA.
This is why you always test it before you put it in.
The mr gasket is much less of a restriction when it's open.
yup u are right should always test therm before u put it in trust me i will for now on!, after I took the bad therm out and put it in a pot of boiling water it never opened!!!!
Fox Thunderbirds and Cougars share the same radiators. I personally understand being out of funds for the car, but you really should just save a few bucks and buy a new one. No telling what shape the radiators are at the salvage yard, and that's an important part for the car. Autozone carries heavy duty pieces, and Ebay has them as well.
Unless you buy someones quality used aluminum aftermarket radiator, don't waste your time on a used one.
Try pepboys or autozone and get a 3 row.
Back in the day i payed $129 for my one from pepboys and it served me well for years.
It was at least twice as thick as the stock radiator.
Fan and shroud only needed when driving less than 40 mph.
The air deflector and incoming air handle cooling after that.
If the car is cooling via fan without shroud at low speed, then the radiator is working.
Check your lower radiator hose.
Most common overheating over 40 mph is due to soft lower hose sucking shut and not allowing water flow. A new lower radiator hose will be needed if it is too soft. Try to get a hose with a spring inside.
If you are broke, you can 'make' a spring out of a coat hanger to keep the hose from closing.
This is a bandaid until you can get a new hose. If you can't find one with a spring, install a spring.
My lower radiator hose does have a spring in it. I guess I could try a new cap. I just thought of something, my tranny cooler is mounted in front of the A/C cooler thing in front of my radiator. Could I have to much there and need to move my tranny cooler?
Some believe the air deflector works, some don't.
I have no experience living in a place where temps are over 105 daily, so in those places i guess it could work.
But NJ has had it's 100 degree days in the summer, and i've never had an air deflector.
One would think in North Dakota, that it wouldn't be an issue there either.
