thump went turning on radio
so is there a problem? ur lucky u have any bass.
Lol, he's not talking about thump in the sense of bass. He's talking about a sudden "surge" of sound that comes on when an amplifier turns on after the head unit.
As for the original issue, are you 100% certain there isn't an aftermarket amplifier somewhere in there? It would be very unusual for just a deck to cause that issue at turn on.
With an aftermarket amp, I believe a solution is to put a resistor in line with the speakers to prevent this from happening. Maybe possible with a factory system as well.
Update: I was removing the radio trim panel to paint it and ended up removing half my dash lol. So anyways here is what I found. The harness they used to adapt to the factory wiring only has one large plu and a smaller plug connected to a grey wire and small black terminal. Now where I am confused is there are three of the grey wires with black terminals and only one is connected. I am guessing these leads go to the factory amps. Is something wrong or is this normal?
