Blown Header gasket back pressure ?
Pops Fun
961
14
59
Cincinnati, Ohio
Hi
Just changed my engine combo making 623rwhp , put my cats on to quiet down the roar...
Must be getting old. :) Then blew the exhaust gasket , wondering :
Could the exhaust changes, (Cats) put more pressure on the header gasket and blow it??
I see you're running Mac's....blowing out a header gasket isn't uncommon and it has nothing to do with you running cats.
The individual flange design they use is a poor one. The pipes flex and move around with the various heat cycles and once the headers have been removed, they almost never line up and seal the same. My advice to you would be to spend some money on some good gaskets (not the cheap crappy paper ones Mac gives you with the pipes) and add a liberal coating of high temperature copper silicone to both the header flange and the header gaskets before bolting them back on. Then, tighten them uniformly from the center outward, torquing them on in stages.
That's what I had to do to finally seal up my last set of Mac's. They're not a horrible header, but they aren't exactly maintenance free either.
I wouldn't say it's the cause, but running cats on an engine making that kind of power isn't really a good idea anyway. They definately do cause back pressure, but in all reality cars making that kind of power have a tendancy to blow header gaskets.
Kurt
JBA Ford Shorty Headers
They have nice thick flange??
http://products.jbaheaders.com/detail_shortyV.asp?id=1624S-4JS
Sorry, I was under the assumption that you had the Mac headers listed in your Car Domain link?
JBA's are pretty low end IMO. I'm not sure what the OHV headers are like, but the ones for the modular crowd are notorious for cracking.
In my opinion....if you insist on going with a short tube header, the Ford Racing ones will be your best bet for proper fit and finish.
we're all the bolts torqued down still or did one of them wiggle a little loose? had you retightened them after you heat cycled the engine a couple times? what bolts do you have in there now?
:) I had the mac's didn't like them... The JBA"S flange looks much stronger. My MAC's were pretty bad!!
