Changing Oil Cooler Adapter Gasket
You don't use sealant for parts put together with O-rings. I didn't use sealant when I did the job. Be sure to lube the O-ring before use.
Recommend replacing the block to oil-filter adapter gasket at the same time. Not a very expensive gasket and makes sense after going through the work of draining oil/coolant.
