1992 5.0 Help!
92WMR
Hey y'all, I just bought a new(to me) fox body! So I've gotta button up a few things to get her going.. She needs heater hoses, all coolant hoses installed, fuel lines, trans lines.. Ive got a question though.. with the intake it has a BBK EGR spacer... if I'm running a egr block off plate do i still need to run this spacer? Im new to the mustang world.. any help would be appreciated!!
People usually run the spacer either to 1-separate the hot lower intake manifold, 2-fit larger valve covers, 3-block off egr there if the spacer doesn't have an egr hole cut in the center.
So I guess I'd take a look if you have larger valve covers. But it's nice to have so I don't know why you'd want to remove.
I think he means the EGR spacer between the throttle body and intake. Leave the EGR stuff on the car, it doesn't hurt horsepower, and the computer changes fuel strategies under cruising loads.
Reactions: jrichker
yes it bolts to the upper manifold, yes number 51 is correct. On mine there are two tubes that run off it, the back side (fire wall side) i believe runs to the egr valve from pictures I've seen on the internet.. or does it not? can someone trace theirs and find where it leads?
Edit: (See pic below) where the little red caps are.. the front one goes to a hose thats just below it.. where does the back side one connect to?
This is how she sits right now.. still needs some love
There is a nipple in the lower intake (stock) water jacket at the back corner, may not be there on aftermarket intakes, it's for water to circulate inside the egr spacer, depending on where you live and temps you drive in as to if you need it.
so if i don't have the nipple on the intake do i just run w/o it? leave it empty
The one in the back coming off the spacer between the TB and the upper intake should go to a fitting that's screwed into the block.
You can run without it...a lot of people use the spot in the intake for a temp gauge and use a bolt and clamp to plug the front hose.
As far as sub freezing temps, didn't the 1993 Cobra also not run coolant through the EGR spacer? If so, couldn't a person also not run the coolant lines and be fine?
It is actually there to keep the EGR spacer cool. Hot exhaust gas passes through there when the EGR is activated and the engine coolant keeps it from getting as hot as the exhaust gas. Basically, if you have a functional EGR, leave it or reinstall the EGR spacer coolant hoses.
Reactions: General karthief
