2006 Door Panel
Hdpanther1
Dayton
I'm sure if you have a 2005-2009 you have either had or know about the issue with the fabric separating from the door panel. I was looking at a 2010 today and started thing, would this door panels from a 2010 fit on my 2006? I wasn't sure if they changed the chassis much or if the doors are still the same. Thanks in advance for any help.
Yeah they can be swapped in. I wrote this up a couple years ago when I did the swap:
https://www.s197forum.com/threads/10-14-door-panel-swap-into-05-09.131456/
Others have told me they don't require this much effort, I wanted as close to an OE fit as possible.
Be aware the inserts will fall off of these ones too, mine already started to, but they are easier to fix (smaller inserts).
It is quite easy to replace the material. Without removing the panel.
Thank you so much for your reply. I kinda figured they would and you confirmed that. Here is a picture of before and after of my 2006. I've done a little more since the bottom picture was taken.
Ha
