It's Grilling Time! The Official Stangnet Grill/Smoke Thread
Hummmmmmmm.......I’m doin’ a bit of larnin’.
So, the starches from the potato skins in combination with the salt and oil emulsify the coating from the factories applied to the bare cast iron. Primarily those found in the pits made from the initial sand casting. In short, it really helps clean the crap out of the skillet from the factory protective coating. Wether it be wax or oils.
So it’s great for the initial cleaning of the new metal. Yet the manufacturers claim this helps to season the new metal.
I also read a few sites that tested wiping down grill grates with a potato helps to make it non stick. Through various tests they have conducted, I tend to believe their results.
I have yet to read connecting thoughts of why the potato would offer any non stick protection for seasoning cast iron. It would seem that from manufacturer instructions that I would deduce that the oil itself used along with the skins and salt is the main “seasoning” factor in that particular function.
Potatoes are somewhat higher in Omega 3 fatty acids, something flaxseed oil uses effectively to provide a non stick surface in conjunction with heat.
So, I’m guessing here now since my background is in painting cars, maybe the potato skins tend to raise the Omega 3 level of the seasoning oil that we know help to build a nice initial seasoninig in a new pan?
It also sounds like the salt and potato would make a wicked good cleaner for your skillet with really baked on crud too.
I’ll read more to see if I find contradictory views to what I suggest here.
Reactions: Ronin38
I've never needed to clean a cast=iron pan with anything other than hot water.
I use the potatoes just like you did. Season the pan, cook some bacon, cook some taters, and leave the pan hot with oil.
The combination of starches and oils and general maintenance, give me a surface suitable for cooking cheese. :nice:
@Davedacarpainter I love watching Guga cook! He's the reason that I decided to do the dry aging of that steak last year. I've also gotten a lot of ideas from him about things I can cook with the sous vide. He has a channel called "Sous Vide Everything", and, well, he Sous Vides everything!
Sous vide a steak at 118 for a couple of hours, then drop it on a hot cast iron pan or griddle for a quick sear on each side. It's the best steak you'll ever cook.
Reactions: Olivethefet
I'm going to make some waves here but I use cast iron frequently with no issues. I cook in it I clean like everything else in the sink. I dry it on the stove. I dont put it in the dishwasher. I dry it on the stove with heat. I've never noticed any weird taste. I know a lot of people get upset if you use soap but I haven't had a problem. Im not saying I'm right and they are wrong. Thats just my experience.
Get a good pan. Season the hell out of it and go to town. Use soap sparingly and life is good. If you want be a purists and only use salt and oil. You'll be fine.
I think the major issue is not drying them properly. Never put them in the dishwasher or let them sit in water.
Cook. Clean. Dry.
Reactions: RaggedGT
I would love to use a cast iron properly, but the effort just seems to be too much for my lazy arse. LOL.
It's really not after you get the first seasoning done.
Rinse, oil, heat, lid, and let it sit. :shrug:
I haven't 'washed' a piece of cast-iron since it was new. Some of it belonged to my grandmother and hasn't been 'washed' since before I was born.
Reactions: IIGood
