evintho 20+ Year Stangneter Nov 12, 2003 683 245 73 Santa Rosa, CA. Dec 2, 2022 #1 Dec 2, 2022 #1 Mine slides in and out easily. If I turn the lower intake upside down, the grommet will fall right out. Shouldn't it be tighter than that?
General karthief wonder how much it would cost to ship you a pair 20+ Year Stangneter Aug 25, 2016 27,951 10,589 203 polk county florida Dec 2, 2022 #2 Dec 2, 2022 #2 Actually yes, mine was kinda snug when the valve was installed, I used some blue RTV on the grommet to help seal it to the intake hole.
OldManRiver Active Member Feb 14, 2015 238 131 53 Central Wisconsin Dec 2, 2022 #3 Dec 2, 2022 #3 I've found only the Motorcraft grommet fits tight,but will cost you $30. Otherwise just wrap electrical tape around the valve to expand the OD of the grommet for a tighter fit in the intake. Reactions: Mustang5L5
General karthief wonder how much it would cost to ship you a pair 20+ Year Stangneter Aug 25, 2016 27,951 10,589 203 polk county florida Dec 2, 2022 #4 Dec 2, 2022 #4 Electrical tape? Ahhh, heat and oil may make that stuff kinda gooey and likely not a good seal, an RTV type product would be a better choice. JMO
evintho 20+ Year Stangneter Nov 12, 2003 683 245 73 Santa Rosa, CA. Dec 2, 2022 #5 Dec 2, 2022 #5 Sounds like a plan. I'll smear some black RTV on the outside ribs and slide it on in. Thanks all!
Dan02gt mazing how much gas smell came from that tiny hole 20+ Year Stangneter Mar 2, 2003 909 415 113 Greenville, NC Dec 3, 2022 #6 Dec 3, 2022 #6 evintho said: Sounds like a plan. I'll smear some black RTV on the outside ribs and slide it on in. Thanks all! Click to expand... That’s what I did and it works fine. Reactions: evintho
