70 fastback: Good battery, but nothing happens.
hankmeister
9
1970 351C, 4 speed.
Was a random occurrence previously. I could be rolling up to a stop light, put in the clutch, and it'd die. But then after a few seconds, it'd start again. Or I'd be driving along, and all of a sudden the alternator gauge would bury out to the positive. But now the car does nothing when I attempt to start. No starter engage/crank, no solenoid click, nothing. AFAIK there is no clutch/neutral safety switch, and I've owned the car 40+ years.
The battery is new/good. When I open the door, turn on the lights, turn the key to "start" position, basically engage anything electric, the alternator gauge bottoms out to the negative side. Haven't tried jumping the solenoid yet to see if it cranks then. Have had some other issues, such as my horn & hazard lights blew a fuse, so I think I may have a short somewhere in the steering column. (When I replaced the fuse, the flashers worked - but when I wiggled the steering wheel into the "lock" position, it blew the fuse again). The last time I drove the car - about 4 weeks ago - it happened but restarted, but the alternator gauge bottomed out on the high side (charging) for the entire drive.
Any thoughts greatly appreciated.
Hank
I'd pull the steering wheel off and examine everything inside of the column for dirty or burned connections. I think there were just 2 or 3 short screws holding most of the electronics in there, this connector is a good place to look too.
Check your fuse links by the starter relay
That power to the ignition switch comes from there
If your alternator pegged you may have burnt a fuse link
Are you still running an old-points style regulator for your alternator?
Well, on a 70, there are three electrical things going on in the steering column. Horn, emergency flashers, and turn signal. Both the horn and emergency flashers use direct battery power (there on all the time) and any short in those could result in a dead battery. I would start there, pulling the steering wheel and examine the turn signal/emergency flasher switch. You can also see if the horn copper buttons are in place. Usually when those go bad, you get an audio signal. I would also check to see if the voltage regulator is bad, especially if you have an original pints style version. Here is a simple Reg test process I stole from Bigb427 @ VMF:
1) engine off, test battery voltage.
2) engine running at 1500 - 2000RPM battery voltage should be at least 1 volt higher than step 1, but not higher than 14.7 volts.
3) If step 2 is ok, then look for a drain on your battery, or the battery itself might be deffective
4) If step 2 is lower than you have a bad alternator or regulator. If step 2 is higher than 14.7 you have a bad regulator
5) If step 2 was lower full field the alternator by jumping the "A" & "F" terminals in the wire harness that plugs into the voltage regualtor. See pic: http://thelincolnmarkviiclub.org/Gallery/albums/album92/VR_illistrated.sized.jpg The markings "A" & "F" might be different. This is ok, the position is what is important.
6) If full field voltage tested at battery is still not at least 1 volt higher than step 1 alternator is bad. If it is now more than 1 volt higher regulator is bad.
Things to add: unplugging the regulator with the engine running will not harm anything other than discharging the battery.
Disconnecting the battery with the engine running may indeed harm the alternator - do not do this.
Let us know what you find and good luck.
Had the steering wheel off to swap out the turn signal / emer flash assembly (turn signals worked, flashers didn't, turn sig stalk wouldn't "snap out" after the turn). Everything seemed to look ok, but could only see so much.... And other than the turn signal stalk returning to center after the swap, no other change.
best
H
Everything under the hood looks okay, but we're dealing with a 55 year old harness (give or take), so something under wrap might be wonky.
I replaced the volt regulator with a Marti repo that I ordered a while back and just hadn't installed yet. The old regulator cover popped off in my hand upon removal, so I'm pretty sure some moisture got in and caused some corrosion. Got her started and driven after the swap, seemed to cure the high/low pegging of the alternator gauge.
best
H
Swapped out the regulator, that seemed to fix the pegging issue.
There's no horn/flashers at all, so somewhere in that harness there's a short. I did swap out the appropriate fuse for them, and they worked until I wiggled the steering wheel into lock position, which blew the fuse again. (As mentioned in original post) So I'm hoping/thinking as mentioned above the ignition switch (age unknown, but not the original) has reached it's effective lifespan, and swapping that out will remedy things. If not, then it's the dreadful task of tracing wires from A to B to C, and finding the short.
MANY thanks to all for tips & suggestions. Greatly appreciated!
H
I wonder if the power to the horn button is grounding out on the column. Those two little copper, spring loaded buttons, can come out of their holders and arc as you pull the wiring. That might explain your issue. You might pull the steering wheel, replace the fuse, wait until dark, pull the wiring, and see if you can see arcing in that area. Just an idea to explore.
