It will definitely keep me busy this winter! Yeah, they have 8,9,10 widths.Sounds like a big undertaking but will definitely be worth it! The 13” front/rear brake rotors are a nice touch, not something you see often.
Didn’t know they made 10” Pony’s. The staggered look will be sweet.
That's gonna look awesome. Your studs should be just fine. I doubt you'll need any spacers...atleast not big ones.
I'm excited about it. I know I'll need studs for the new rear axles because they don't come with any. Not sure if the new front hubs will have long enough studs. I shouldn't need any spacers as far as I can tell.
One oddity of the 17" Pony wheels is the hub area is thicker than any other wheel I've ever seen. They have a smaller backspacing (push the barrel of wheel out) than the factory 16" Ponys for better tire clearance and widths, and a more modern look. However they kept the center section of the wheel almost flush with the outside rim edge. I believe this is to matain the factory look and not have a "deep dish" pony wheel. It wouldn't really look the same that way. So to get the desired offset and look they make the hub area thicker.
Pic below shows how deep the hub area is.
Currently my 4 lug Ponys have just enough stud for a lug to cover almost all the thread. It's very close to being a no go. Honestly it bugs me how close it is. Pic below.
So if the new 94+ sealed bearing hubs have the same length studs I'm going to swap them out for something longer.
One advantage of the extra thick hub area is it keeps the inside face of the wheel center section out quite a ways from all the brake parts. Because of that I'm able to fit some pretty moster calipers in there!
I just pulled the trigger on some new wheels. 94-97 cobra rims. I don't know why...but I like them on a fox when the car is dropped a bit.
Appreciate the update!
Nice. I'll have to go through your thread and check em out! There are alot of wheels that I really like on the foxbodies. Those should look great. For some reason the stock-ish exterior look is what I love. At first it looks stock, then the more you look the more it become apparent it's not. The staggered Ponys on a slightly lowered chassis have a sneaky custom look, to me anyway lol.
