02 GT NEW PUMP LOW PRESSURE?
khalistang1
Madison WI
HELLOW FELLOW STANGERS KAHLISTANG HERE AND I HAVE A 02 GT I WASNT HEAERING FP KICK ON SO GOT NEW 1 NEW PUMP COMES ON BUT NO PSI ON RAIL I DISCONNECTED FUEL LINE FROM RAIL TURNED KEY TO PRIME SMALL STREAM COMES OUT ANY HELP WOULD BE GREAT
If this were my car I would use an ODB2 scanner to look at the fuel pressure PID. What we are looking for is to see IF the PCM is seeing a value from the FRPS. Monitor the FRPS. Watch the FRPS as the key is cycled. Does it change? Does it change during cranking?
Also monitor the RPM's signal during cranking. Does it change?
Here is some information on an affordable but powerful ODB2 scanner.
ForScan ODB2 scanner w ELM327 USB​
A couple of notes. It does take several key cycles for the fuel pump to build full pressure. The process needs to get all of the air out of the system.
Note, a bad FRPS is a "no start" sensor.
Reactions: COramprat
