  • SN95 4.6L Mustang Tech
02 Water leaking HELP!?!?
  • Thread starter Thread starter SGOODRIC50
  • Start date Start date Aug 7, 2005
SGOODRIC50
130
Maine
Aug 7, 2005
  • Aug 7, 2005
As I was driving home last night my wife said, "My foot is getting wet." I stopped the car and sure enough water was coming out from underneath the dash. It would stop leaking out when I turned the A/C off. After further investigation this morning I found that it leaks water under the dash when the blower fan is on whether it is the a/c or not and I cannot figure out where it's coming from. It's just pure water! Not Coolant and not a/c refrigerant. That rules out the possibility that it is the condenser and the heater core so what could it possibly be? I thought that it may be the hose the lets the condensation leak to the outside of the vehicle but where is that hose located, and why would it be coming from the edges of the blower motor housing? Any ideas?
crew_dawg16
445
DeKalb, IL
Aug 7, 2005
  • Aug 7, 2005
Well, I know that the condensation hose drips on my pass. side header which is by the blower motor I guess. I've never heard of one leaking to the inside of the car though.
You don't have a warranty left?
jstreet0204
939
Winston Salem, NC
Aug 7, 2005
  • Aug 7, 2005
Mine does the same thing. I'm pretty sure it is just condensation.
SGOODRIC50
130
Maine
Aug 7, 2005
  • Aug 7, 2005
it drips a lot, to the point that if I drove the car for an hour with the a/c the floor board would have aboue 1/4" of standing water. I have determined that it is the condensation hose because it doesn't leak onto the ground. I just need to figure out how to get at it....
AdRock
521
South Texas
Aug 8, 2005
  • Aug 8, 2005
I bet the drain hose is clogged so the water is just backing up. It's gotta go somewhere.
forpit2000gt
2,490
Columbia, SC
Aug 8, 2005
  • Aug 8, 2005
the drain hose is clogged, need to clean it out.
COBRA90GT
Mustang Master
Sep 22, 2001
6,654
HOCKEYTOWN ® , MI
Aug 8, 2005
  • Aug 8, 2005
BTW - Soak up the moisture (if there were "puddles" of water) from the damp carpet to prevent any chance of mold growing...it's nasty stuff!
SGOODRIC50
130
Maine
Aug 8, 2005
  • Aug 8, 2005
How do I unclog the hose?
AdRock
521
South Texas
Aug 8, 2005
  • Aug 8, 2005
The last time I had to unclog one I used a coat hanger.
M
mode101
202
Dallas, TX
Sep 21, 2006
#10
  • Sep 21, 2006
  • #10
Old thread.
Is there a diagram that shows the common hoses that get clogged, and other drainage hoses that need to be checked from time to time?
I have an 02 vert with water coming in when it rains.
CRZYHRSGT
240
5.7 miles north of THE Ohio State University
Sep 21, 2006
#11
  • Sep 21, 2006
  • #11
mode101 said:
Old thread.
In this case check for debris under the cowling (under the wipers). If you have a bunch of leaves and other crap in there the water could fill up in there and go into your air intake for your ventilation system.
E
  • Sticky
2003 Mustang GT convertible water leak
  • Eightiesrock1980
  • Jul 27, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jul 28, 2026
K
86 GT Water Pump
  • Kade5114
  • May 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 11, 2026
nickyb
Interior and Upholstery Water leak, passenger side, ripped seats and carpet out already.
  • 2000ElectricGreen
  • Mar 18, 2026
1996 - 2004 SN95 Mustang -General/Talk- Mar 24, 2026
squeak93
Water leak from hatchback door
  • jeremyzcook82
  • Nov 24, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 25, 2025
jeremyzcook82
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Nov 1, 2026
manicmechanic007
