03/04Cobra Supercharger on a 98 Cobra
Yes, it will work but it required a ****LOAD of fabrication and work. You could buy 2 KB blower kits for your Cobra (which is FAAAAR better than the Eaton anyway) for as much as you're going to spend getting the Eaton to work on your car :shrug:
as it has been said, would require a load of fabrication and not worth it in the end. the 98 cobra uses swirl port heads where there are 2 sets of intake ports per cylinder. the 03/04 cobra uses tumble port heads which have only 1 intake port per cylinder. you might as well just buy a kenne bell for the time and money it'll cost.
