  • SN95 4.6L Mustang Tech
'03 GT Fuel Pump/Pressure/Delivery Issue
  • Thread starter Thread starter Brodach
  • Start date Start date Oct 21, 2025
  • Tags Tags
    fuel delivery fuel pressure fuel pump
Brodach
Texas
Oct 21, 2025
  • Oct 21, 2025
This relates to a 2003 Mustang GT, no major mods, just a standard stock '03 GT. Also, I apologize for the long post but I feel like context is needed.
I will preface this to show how I got to where I am:
Back in 2017/2018 my fuel tank was rusted and causing a leak. I replaced the tank, moved the valves over, etc. put in a new fuel pump. I cannot recall what brand of pump -- it wasn't nice but also wasn't incredibly cheap. Everything is fine. My old pump was working, but it was a 15 year old stock pump at that time, I felt better to replace it while I had the tank out.
Fast forward to late 2022/early 2023. I start having issues (especially when making a hard turn and when fuel is getting under half a tank) where the car will sputter and try to die. Does okay with fuel topped off. I figure the "okay" fuel pump I purchased in 2017/18 was the problem, so I again replace the fuel pump. This time I went pretty cheap. Maybe $120 or so for the whole assembly -- I was telling myself I would be buying a new vehicle soon, so cheap will last until then when the Mustang becomes a project car. I slap it in there and the problem goes away.
Fast forward again to a month and a half ago. Car is running fine one day, I think I was down to maybe half a tank of gas drive the car, go home park it. I go outside the next evening, try to start it -- it cranks but won't fire up. I notice I don't hear the pump priming at all, so I pull the fuel line from the rail and turn the key, sure enough no fuel. This time I just think because I cheaped so much on the last pump that this is what I get and it already died. So, I again drop the tank and replace the pump. This time I don't cheap out and I get a Walbro TU229HP (255 LPH) -- pretty common pump. I install it, care fires right up, no problem -- runs just fine.
Now, we get to the other day -- the car has been running fine for about a month and a half now. Friday everything is fine, I fill up the tank (which is awesome considering I may have to drop the tank again) that night go home. Saturday, everything is fine, I drive at least once. Then Sunday I go out in the morning and try to start it, it cranks for a long time, won't start. I throw my hands in the air thinking that ANOTHER pump has died. I give it one more try, it turns over and runs just fine for the trip to where I was going and back. It started up just fine for the return trip. Later Sunday night, I start it up again, no problems. This time while driving I make a left turn onto a higher speed road, start to hit the gas and it just completely bogs down and dies. So I'm stuck in the road -- I turn it over a few times and it will start and either immediately die, or die the moment I touch the gas. I spent 3-5 minutes trying to get it going, eventually I do (this is probably completely unrelated, and I don't recall if I did this before or after I successfully got it running enough to get it out of the road, but I turned off the A/C). I park it in a hotel parking lot 20 feet from where it died for the night as it was late and didn't want to deal with trying to get it home at that moment.
The next day I go back to get it. It starts right up, maybe a slightly longer crank -- runs very poorly. Rough idle, constantly bogs down when I give it gas -- I'm having to finesse it the whole way back, but it never dies on me.
I get back to my house, get it in the garage and go grab my diagnostic tools. I pull codes and check fuel pressure. Pressure was VERY low. At idle is was sitting just under 10 PSI*. The only codes showing up where Cylinders 1 and 5 misfires. I decide with the information I have to wait till tomorrow (now today) to start messing with things.
Today, I go out and just first thing try to start it up to verify that the fuel pressure I saw last night was accurate. It cranks and cranks and cranks and won't start. Pump is once again not priming. I do my usual disconnect of the fuel lines to see if anything comes out. Nothing. I tell myself that there HAS to be something else wrong -- this many pumps in this short of a time is not right obviously. I check the pump fuse, I get out the multi-meter and start checking voltage at connections. Everything is fine, there is power going to the pump. Frustrated I plug the pump back in, not expecting anything to happen I put the key in and turn it, and the pump primes. I do this a couple more times to make sure it wasn't a one time fluke. I hook the fuel line back up and start the car up just fine. I check the fuel pressure and it is priming to about 60 PSI* then idling around 40 PSI*. No misfires, no stutters, just running exactly how it should. I did notice that pressure drops off pretty quick when I shut it down, it doesn't go straight to 0 but within maybe 2 minutes it was already under 20 PSI. I assumed it would hold higher pressure longer.
After Googling, I know there are many things to check (CCRM, FPDM, FRPS, possibly some electrical connection somewhere? Or the IFS switch going bad? I also made sure it wasn't triggered) -- has anyone encountered something like this before? I know a lot of people will think it's just the pump -- and I know it is entirely possible I got unlucky and got a dud, but I don't think a car should go through this many pumps in 7-8 years? Also, I never got a CEL for anything this entire time. I'm thinking about replacing the FPDM either way, it's cheap and I can get to it quickly, even though I believe you generally get a code for a FPDM issue.
* Fuel Pressure was measured via OBD2 and app, but, based on how the car was running before and after I believe it was correct.
- No fuel present in the FRPS vaccum line.
Again, sorry for the long post, but this car has been frustrating lately. I appreciate any possible help. Let me know if you need additional information -- I may be forgetting things I have done or checked right now.
TLDR;
I'm on my (possibly) 3rd dead/dying fuel pump in 7/8 years. Latest fuel pump wasn't cheap. Suddenly car started bogging down, low fuel pressure, rough idle -- all within one day after 1.5 months on a brand new fuel pump (long crank to get it started earlier in the day but was fine for a while). Fuel pressure showed just under 10 PSI at idle. Next day while doing diagnostics, disconnecting and reconnecting the fuel pump harness magically fixed the problem. Clearly there is still a problem but trying to figure out the best approach.
Brodach
Texas
Oct 21, 2025
  • Oct 21, 2025
I wanted to add that I did replace the fuel filter every time the pump has also been replaced.
P
PSKSAM2
771
NJ
Oct 22, 2025
  • Oct 22, 2025
Crazy sequence. Odd question, but what time s your habit on filling up the tank? Do you wait until it is dry empty every time or fill up before? Just wondering if maybe the lack of fuel on the in tank pump leads to premature wear due to overheating as it is cooled by the fuel in the tank.
Brodach
Texas
Oct 23, 2025
  • Oct 23, 2025
Thank you for your response -- well in the past I was bad about that and would let it get below 1/4 tank, but on this fuel pump, and the fuel pump prior I would generally never let it go much below 1/2 a tank before filling up -- because I did wonder if that was the issue after burning through that first pump in under 5 years.
I also got in the habit of doing that because the floats/senders on those cheap pump assemblies did not seem phenomenal -- I did not trust my fuel gauge (there were times on the pump prior to this one where I would put in 10-11 gallons, but the gauge was claiming I was pretty close to half a tank).
So it is possible that the pump I installed in 2022/23 (and maybe even the pump before that) could have overheated occasionally due to incorrect fuel level readings. But since I installed this latest pump a month and a half ago, I don't believe I have filled up more than twice -- and I think the most fuel I have put in at any one time since installing the new pump is maybe 8-9 gallons (to full). So it should have remained submerged and cooled. I do not drive a ton -- I generally have to fill up twice a month, at most.
P
PSKSAM2
771
NJ
Oct 23, 2025
  • Oct 23, 2025
I understand why you are looking for something else. Admittedly I don't have a lot of experience here, other than having replaced the pump in my 02 after 20 years.
- FPDM seems weird, if a new pump has 'fixed' it before. Maybe if it is driving too much.
- How about the fuel injection pressure sensor? Maybe it is reading low, and keeping the pump running too much, burning it out? Trying to square this with the readings you took. Maybe at least take it off, clean, reinstall?
- Leftover contamination from the rusty tank? Maybe in the filler neck or another connection? Return line?
- Gas from the same station or varied? Seems unlikely, but asking anyway.
Admin Dude
Jan 4, 1985
43,335
21,526
234
Box behind Walmart
Oct 23, 2025
  • Oct 23, 2025
With what exactly?
I've gotten pumps from parts stores that were complete garbage right out of the box.
Ensure the pump is a true Walbro and some copy-cat knock-off that looked like the same thing at a better price.
I know two [cheap fakes] off the top of my head that come from Autozone, Pep Boys, and others under the names, "Antex" and "Intex". There are others, of course.
Brodach
Texas
Oct 31, 2025
  • Oct 31, 2025
Sorry for the slow reply, busy week. Thanks again for your reply.
So far I just went ahead and replaced the FPDM, CCRM, and Fuel Rail Pressure Sensor to try to eliminate as many pieces as I can. I also cleaned all the contacts and inspected all the wires. I did not replace the inertia sensor however as of yet, but I really don't think it is that. The current pump is under warranty until September 2026 so I'm hoping I can rule it out or figure this out by then.
It could be contamination from the original tank at first, but, I would think I'd have seen more issues earlier on. That being said, the filler neck isn't expensive -- if I end up dropping the tank again. The gas in the tank (every time I have now dropped and replaced the pump) has looked okay -- not that I would probably be able to tell but it was the correct color.
With this being my 3rd pump since 2018, it has been varied gas. I lived in Indiana for about 2 years after replacing the pump the first time before moving to Texas. Since pump install number 2 I have been getting gas generally from the same station near my house.
The weird part to me, and the most annoying, is that it worked fine for about a month, then suddenly low fuel pressure and misfires, then acts dead the next morning. But unplugging the pump from the harness and plugging it back in made it work again. After doing that, it started running fine -- I replaced the above mentioned parts, and it is still running fine after that. Not a huge fan of the randomness of it and just having to drive until it breaks again to see if I made the right choices.
Brodach
Texas
Oct 31, 2025
  • Oct 31, 2025
Noobz347 said:
With what exactly?
Thanks for your response.
Well, I replaced the filter with a Motorcraft FG1114 each time.
As far as the pump goes -- the first one wasn't that great, I think it was Delphi -- it was cheap -- that is the one that died (at least I believe it died) back in September and only lasted 2-3 years.
However, the last one was Walbro (supposed to be TU229HP-2) to my knowledge -- the pump I just installed in September, that might be causing me issues. It was more than twice as much as the Delphi pump, I ordered it from LMR.com. I guess I didn't pull the pump out of the assembly (purchased pump and assembly together for ease) and check the serial number on it or anything like that -- I just assumed they sent me the correct part. That being said I did contact them about the part and it has a one year warranty -- if I can deem that it is in fact the pump dying.
With it running right now (but I do not trust it) -- I think I'm going to run the gas low, drop the tank and check things out. Maybe even see if they will let me warranty the pump. As mentioned in my above post, it's weird that it worked, then seemed to slowly die, then acted like it was completely dead. Only to resurrect after disconnecting and reconnecting the harness (as still working after FPDM, CCRM, and FRPS replacements).
gkomo
now i can hopefully expect to receive the shaft
Aug 2, 2024
2,260
1,479
133
San Diego, CA
Oct 31, 2025
  • Oct 31, 2025
Is the connection you are disconnecting/reconnecting making a good connection? Not wiggling loose after driving for a bit?
C
98 gt fuel pressure issues
  • chasecollier1984
  • Jun 2, 2026
SN95 4.6L Mustang Tech Jun 2, 2026
chasecollier1984
C
F
2004 Mustang GT – Fuel Pump Not Priming
  • Fayio
  • Apr 22, 2026
SN95 4.6L Mustang Tech Apr 27, 2026
n0v8or
N
9
1997 gt Starts then dies a few seconds after.
  • 97orange
  • Aug 13, 2026
SN95 4.6L Mustang Tech Aug 17, 2026
97orange
9
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
L
2003 mustang v6 3.8 fuel issue
  • lacole1
  • Jul 20, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jul 26, 2026
apple99Mustangdude
A
