whyask New Member Apr 4, 2005 735 1 0 Sacramento Nov 15, 2006 #1 Nov 15, 2006 #1 How to ?.....could not find in any threads or post. Thanks guys:SNSign:
kid rock New Member Jan 24, 2006 99 0 0 THE 51ST STATE!! Nov 16, 2006 #2 Nov 16, 2006 #2 disconnect the negative battery connection for half hour then reconnect! Si :SNSign:
Don 95Vert Founding Member Oct 1, 1999 1,091 1 39 Delaware, OH Nov 16, 2006 #3 Nov 16, 2006 #3 Or, if you are in a hurry, disconnect the negative battery wire, step on the brake 5-6 times (brake lights drain the capacitors) and reconnect.
kid rock New Member Jan 24, 2006 99 0 0 THE 51ST STATE!! Nov 16, 2006 #4 Nov 16, 2006 #4 nice one don ill remember that myself! Si
K Kilgore Trout Fried or Broiled ? 10 Year Member Mar 30, 2005 4,749 95 134 Nov 16, 2006 #5 Nov 16, 2006 #5 You will know you did it right if you see all your guage needles sweep when you start the car up after the reset.
whyask New Member Apr 4, 2005 735 1 0 Sacramento Nov 16, 2006 #6 Nov 16, 2006 #6 thanks fellas , ill be going with option "b" thanks DON
whyask New Member Apr 4, 2005 735 1 0 Sacramento Nov 16, 2006 #7 Nov 16, 2006 #7 how long should I drive it and what is the process for the car to learn all the crazy curves again
K Kilgore Trout Fried or Broiled ? 10 Year Member Mar 30, 2005 4,749 95 134 Nov 16, 2006 #8 Nov 16, 2006 #8 Its in the owner's manual...
merc123 Active Member Jan 27, 2003 420 2 39 North GA Nov 16, 2006 #9 Nov 16, 2006 #9 whyask said: how long should I drive it and what is the process for the car to learn all the crazy curves again Click to expand... Drive it around for a few days of normal driving.
whyask New Member Apr 4, 2005 735 1 0 Sacramento Nov 16, 2006 #10 Nov 16, 2006 #10 ya the owners manual says to do series of test, but I dont have ac and I mainly drive hard all the time
R Robs96 Member Aug 29, 2006 131 1 16 Nov 17, 2006 #11 Nov 17, 2006 #11 Don't worry, just drive it, it'll be fine.
the98stang Active Member Aug 12, 2005 2,408 0 47 Clovis, CA Nov 17, 2006 #12 Nov 17, 2006 #12 my owner's manuel says to drive it for at least 10 miles with the AC on... I don't know if thats absolutely necessary or not..
whyask New Member Apr 4, 2005 735 1 0 Sacramento Nov 17, 2006 #13 Nov 17, 2006 #13 ya i was thinking the same thing, ill just drive it normal with a few hard runs
K Kilgore Trout Fried or Broiled ? 10 Year Member Mar 30, 2005 4,749 95 134 Nov 17, 2006 #14 Nov 17, 2006 #14 Should be fine...
myponyrocks I have more billet on the Stang than most women ha Apr 18, 2004 1,219 0 37 Nov 17, 2006 #15 Nov 17, 2006 #15 driving with the AC on teaches it how to control the idle...
