- Mar 14, 2007
- 5
- 0
- 0
Hi, I'm a newb, and I need some help.
I searched first, but didn't have any luck. Sorry if this has been covered, but I need an answer. Thanks
I've found some cheap 2005-up stock GT 24lb/hr injectors that I would like to use on a pre 05 GT that had 19lb/hr injectors. My question is: What is the stock fuel system pressure on the 05-up GT. Did it change from the 43.5 psi (3bar) System. If it did change, what is the fuel pressure now? (2005-up)
I need to know, so I can calculate what flow I can expect from the injectors I found. The part number on the injector is 4L8E-A4A. I'm hoping that the system pressure is still at 43.5 psi. Any help is appreciated.
I searched first, but didn't have any luck. Sorry if this has been covered, but I need an answer. ThanksI've found some cheap 2005-up stock GT 24lb/hr injectors that I would like to use on a pre 05 GT that had 19lb/hr injectors. My question is: What is the stock fuel system pressure on the 05-up GT. Did it change from the 43.5 psi (3bar) System. If it did change, what is the fuel pressure now? (2005-up)
