1.7 ROCKERS
  • Thread starter Thread starter gwiesem
  • Start date Start date Oct 4, 2006
G
gwiesem
18
  • Oct 4, 2006
CAN ANYONE TELL ME IF 1.7 ROLLER ROCKERS WILL FIT UNDER STOCK VALVE COVERS?
G
GTOreturns
Well-Known Member
Oct 1, 2003
51
17
59
West Coast Best Coast
Oct 4, 2006
  • Oct 4, 2006
Yes they will. I have 1.7 Crane RR's. You just have to cut off the oil baffle.
JChalfan
551
Bellevue, WA
Oct 4, 2006
  • Oct 4, 2006
Removing the oil baffle under the filler is not always a good idea. Some people have problems with oil consumption through the filler-to-TB line after removing the baffle. Read down towards the bottom of this thread for some info:
http://forums.stangnet.com/showthread.php?t=657127&highlight=oil+baffle
Jeff
8950HO
658
  • Oct 4, 2006
I have Crane 1.7`s with the valve cover baffle removed and no oil makes it`s way up.
Roller rockers,(at least these Crane) have smaller oil passages and don`t piss out oil like stock rockers.
D
Daggar
3,902
  • Oct 4, 2006
It will totally depend on the rockers that you're using. My Trick Flows fit beneath my valve covers with the baffle removed but the Scorpions would not.
As for the baffle... There's not reason why you can't put your own baffle into the filler neck itself. I found that a couple of the screens from a meat grinder (yes... meat grinder), placed into the filler neck about 1/4 apart, works great. I'm sure there are lots of things you could find to tack weld into place to keep the oil splash under control.
afast93stang
1,407
North Texas
Oct 4, 2006
  • Oct 4, 2006
+ 1 and I did the same thing.
mob
the guy who hits on his mom
20+ Year Stangneter
Oct 3, 2003
2,566
136
104
Dallas, TX
Oct 4, 2006
  • Oct 4, 2006
put one of those clear type fuel filters in the hose between the t/b and valve cover hose, and you should be fine without the baffle.
G
GTOreturns
Well-Known Member
Oct 1, 2003
51
17
59
Oct 4, 2006
  • Oct 4, 2006
huh,,,never checked mine. Im gonna do mobs idea.
Strype
Cuthbert catcher
61
34
104
Huntsvegas, AL
Oct 4, 2006
  • Oct 4, 2006
Not in combo with a b cam
K
Engine Gt40p vs 180 procomp
  • Kleinjj27
  • Oct 27, 2026
Fox 5.0 Mustang Tech Nov 3, 2026
Kleinjj27
K
T
Oil burning on my recently buil 302
  • The blk67
  • May 15, 2026
Fox 5.0 Mustang Tech May 15, 2026
N
Looking for ECU/CHIP for 1992 5.0
  • Nathan26
  • Sep 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 8, 2026
Qtrhrse23
P
Vacuum
  • ProTechAutoServices
  • Aug 1, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 2, 2026
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
