1/8th to 1/4
  • Thread starter Thread starter FoxRod87
  • Start date Start date Dec 18, 2006
FoxRod87
243
Carolina
Dec 18, 2006
  • Dec 18, 2006
My buddy has an 03 mach I with just gears and exhaust and he run it in an 1/8th and run a 7.79 at 88 what would this be in a 1/4 mile.
LaserRed01GT
Banned
Oct 3, 2006
739
Clearwater, FL
Dec 18, 2006
  • Dec 18, 2006
The NHRA conversion is to mulitply the ET b 1.55. There really isn't a general rule of thumb to convert the MPH. 88 MPH in the 1/8th sure is a strong number for a 03 Mach 1 with just gears and exhaust.
BurningRubber
1,865
24
58
Dec 18, 2006
  • Dec 18, 2006
I dont think that Mach is running 7.79 in the 1/8th w/ just gears and exhaust. Thats somewhere around a 12 flat in the 1/4 mile.
helty
some Ukrainian's enjoying a handjob via my credit
Mar 30, 2005
1,461
Baltimore, MD
Dec 18, 2006
  • Dec 18, 2006
maybe 8.79, definitely not 7.79.
theres not magic forumula, no special calculator that will give you a real accurate 1/8 to 1/4 conversion. They may give you a rough idea, but there are way to many variables to consider.
Stan Weiss
347
Philadelphia, PA
Dec 18, 2006
  • Dec 18, 2006
I will guess 12.20 at 108 MPH. That said what was his 60 foot time? What kind of rear tires was he running? What gear ratio did he have in the rear?
FoxRod87
243
Carolina
Dec 19, 2006
  • Dec 19, 2006
weld prostars with 26x11.5 et streets, and 4.30s . 60ft was 1.64 spinning. and yes it was 7.79 at 88.
Stan Weiss
347
Philadelphia, PA
Dec 19, 2006
  • Dec 19, 2006
That is a pretty good 60 foot time. Based on that with the other times his 1/4 time maybe closer to 12.3-12.35.
LaserRed01GT
Banned
Oct 3, 2006
739
Clearwater, FL
Dec 19, 2006
  • Dec 19, 2006
Very impressive 60 footer and 1/8 mile numbers. The 4.30's and the ET streets earned him the good little end numbers.
R
rogers
339
  • Dec 19, 2006
Your buddy need to get the 60's on down. Get the ET Street off and put a set of 26x10 ET Drags. What's done to the suspension? If you can get your buddy on here I would like to know his launch and shift RPM. Also how much air pressure was he running in the ET Streets.
mustangman9812
661
Mars Hill, NC
Dec 19, 2006
#10
  • Dec 19, 2006
  • #10
Wow I want a Mach 1 :<
crzyhrse99
259
Kansas
Dec 19, 2006
#11
  • Dec 19, 2006
  • #11
http://www.eldemoniorojo.com/calculator.htm
Like someone else said, too many variables .....but heres an estimated chart.
Gearbanger 101
Straight Outta Locash
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Dec 19, 2006
#12
  • Dec 19, 2006
  • #12
Yeah....cause a 1.64 60ft time just sucks.
propellerhead
1,541
&quot;but what's with the but shots?&quot;
Dec 19, 2006
#13
  • Dec 19, 2006
  • #13
I've seen multipliers of 1.56, 1.57 and 1.58.
LaserRed01GT
Banned
Oct 3, 2006
739
Clearwater, FL
Dec 19, 2006
#14
  • Dec 19, 2006
  • #14
Yeah, I have seen quite a few different variances of the multipliers throughout different NHRA and IHRA literature as well. But they are just to roughly estimate what your 1/4 ET would be, and if we take them to mean just that they are a pretty good tool.
Only thing is they don't account for alot of the variables like has already been noted. It is not uncommon for a relatively stock car to rip some awesome 60 ft, 330 ft, and 1/8 mile numbers, especially with alot of gear and slicks. The big end of the 1/4 is where the HP really factors in. So if this same guy were to run an actual 1/4 mile, he might actually be more in the upper 12's.
Nevertheless, he has a car that is digging pretty hard for a relatively unmodded chassis/suspension.
R
rogers
339
#15
  • Dec 19, 2006
  • #15
Gearbanger. A 1.64 does suck when you go 1.25-1.28 on average.
If the car has any suspesion mod it should go 1.55-1.58. But alot depend on getting the car to hook. The track prep, tires, suspension adjustment, etc, etc. He would see alot of improvement by getting a real set of slicks:nice. I have never had any luck with the ET Street.
FoxRod87
243
Carolina
Dec 20, 2006
#16
  • Dec 20, 2006
  • #16
The et streets are what he drives on the street with and yes slicks would do better, and also the track sucked that day. He never got a good burnout the rearend wanted to keep going to the left. It just barely started to smoke the tires.
J
Lack of power on acceleration
  • jameshernandez
  • Aug 30, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 6, 2026
jameshernandez
J
J
2003 Mach 1 Wiring
  • JohnnyUtah
  • Mar 22, 2026
1996 - 2004 SN95 Mustang -General/Talk- Mar 23, 2026
squeak93
D
4.6L 4 valve Sleeve
  • DangStitches
  • Oct 10, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 20, 2026
DangStitches
D
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
DangStitches
D
1970 Mach 1 voltage regulator
  • 70ivygreen
  • Oct 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 27, 2026
Mcmahst
