nillle New Member Apr 24, 2005 12 0 0 Sweden May 26, 2006 #1 May 26, 2006 #1 Hi! Would a 10.5" clutch kit (for 289/302) fit with a 11" flywheel connected to my 351W?
D D.Hearne New Member Sep 29, 2000 11,730 6 0 south louisiana May 27, 2006 #2 May 27, 2006 #2 Only if the bolt pattern on the pressure plate matches the pattern in the flywheel. You can use a 10.5" clutch disc with an 11" pressure plate.
nillle New Member Apr 24, 2005 12 0 0 Sweden May 30, 2006 #3 May 30, 2006 #3 Ok thanks alot! That will help
