this is all goind into my former turbocharged 93 coupe as listed above the car is stripped tubualr k etc the suspension cant get no more done than it is
drag springs coil overs front
rear upper/lower upr's adj and anti roll -2 pinion angle etc it will go 10's with my setup listed above and be very streeable i betcha it goes 10.50's i got a nice 300 hit of juice for it after that i wasnt sure like most of you then i started searchign and reading alot of posts green92lx is in and alot of good info from rick at rnh in those posts...
im gonna use hyd roller cam also 6800 rpm shift point there has to be hyd roller cams that will do that here is a question though will stock lifters and 1.6.1 fms rockers be ok for 6800 or should i girdle those rockers
Kinda like putting a 250shot on a stock 5.0 will run just as fast as a stock 5.0 with a 150 shot. . . . the cam/heads can only take in so much!
